WOOOOOOOOOOOOOOOOOOOOOO finally getting my copy of wow tomorow, about time i get my own copy insted of sharing! anyways, is anyone level lower then 15? if so come train with me and my mate, we can give you a hand.... server is gorgonnash (if i dont lag there neither will you), my name is Clashez =]
hey man what are your pc's specs im thinking about getting a copy tomorrow... because i hear it is easy to level up and thus you dont have to spend hours sitting around to get stuff done so i can still focus on school...
  • Replies 416
Posted Images
the 1st level's are easy.. like you can get to level 5 in around 30mins.. the next five might take a hour.. it does slow down alot later on tho.. like im lvl 35 now and only playing around an hour a day its taking me a week a level if not more
lvl 46-47 took me 12hrs. mainly cause i couldn't be bothered grinding mobs. Was doin quests had to travel all over the place to get the xp. STV, Feralas Hinterlands, Badlands, Uldaman, Tanaris.
I found 2 funny quests last night. A lost turtle in the tanaris dessert needs u to lead him back to his wife. the wife then b1tches him out for getting lost while getting her food and sends him off again.
and the other was in the yeti cave in feralas a chicken needs an escort out.
will be on with kegg tonight for anyone in pranks guild on eonar.
I would post a pic of her here if I knew it wasn't going to get me in a heap of trouble.. Like I said I would give her a go over WOW anyday, but I sure as hell couldn't talk to her..  f**kin g hell is he annoying!!!
just email it to [email protected] and i'll let u off.
when you die, your spirit ends up at the nearest graveyard from your body
now you have 2 choices, one is to get the spirithealer thing to resurect you, giving you res sickness and also making all your equiped items down 25%
OR
you run and find your body using your minimap. this is usually the best option as your body isnt that far off
just to clarify its a 25% drop to there durability not there effectiveness. when the item reaches 0 durability it needs to be repeared or u can just buy a better item, or loot one.
jumped on with kegg last night, need to let some of the other perthies in my other guild catch up so we can do some instances. anyways hunters can kill so easily after they get there pet compared to a rogue at low level.
Haha, ok well the game doesnt only run on the connection, it matters what pc you have to. I have a P4 2.8gz 512MB ram and a 128mb graph card and im on dial up, wow runs like a beauty on it, my standard latency on that game is only around 500-700, and i now start to get lower latency aswell, i guess its also the server and stuff you pick, for instance if you bought the game id advise you to go on gorgannash(correct if spelt wrong). and dont worry about your studies in school, just make a plan like.... when you come home play untill 4:30(if you get home at 3:30) then when you have done your homework and ect thats when you can plan again. Dont listen to them =P if you know some tricks you'll level fast up to at least 9 and then IF anything you might have to start spending some time to get to 14, then it gets hard! school comes first though, so if you think you cant stick with a plan with also doing your homework then dont get the game!
  • 3 weeks later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
