yeah a lot of the times alliance are pretty shitty at pvp unless you find a good group.
shit thing is now the guild im in is having changes, either we split up (due to main members not having time, which is fair enough) or we stay as we are but just do more runs really (we dont organise much unless we are bored or arent in a pug).
i mean i'd consider leaving and TRYING to find another bigger guild for high end instances (anyone looking for ANOTHER rogue?) but i really like this guild, its nice and small and no bad things happen because we dont overwork ourselves. i mean we went into ZF yesterday to help a guildies alt, and we decided to open up all the graves at once to see how quick he could heal us all, whats wrong with that.
and yes, rogues are fun dammit :D
  • Replies 416
Posted Images
finding a MC/ony/BWL guild on blackrock as a rogue will be tough. In general we are the first class knocked off the recruitment lists. best bet if you go down that line is to hand around elwyn forest and watch the general chat for ppl forming new raiding guilds etc. get as many of your buddies to go with if your guild looks like splitting up.
oh and you gotta go do Zulgurub its an awesome instance.
im now in eternal requiem :( though havent really done any runs or anything anywhere with them yet as i just joined 2 nights ago, but their classes are pretty much even but i know what you mean about rogues having a hard time finding a group
wouldnt mind ZG actually, hopefully tonight or something
yeah went well, until rag wiped his ass with us.
but the guild pretty much has every other boss on farm mode. its getting to a point where almost every player of every class has a lot of their epic sets which means that by the time i get enough dkp i'll only need to spend 1point per item :D
its great fun :D
went zg last night
someone accidently started the raptor boss guy after pulling agro from his mate at the bottom of the stairs, damn that was interesting. we all died but just reset and then we smashed him.
got to a point in the 1st "try" that i died so many times the ghosts couldnt bother to res me. hopefully finish it tonight and score me some phat loots!
how laggy has br been since....well...forever, but especially the last couple of days
i got my attunement to bwl last night, a fire resist armor piece from ubrs (leeroys rookery) and i had dibs on generals blood, but someone ninja'd it while i was confirming with everyone, and the other one went to the other person who had dibs, hope i get it tonight dammit, because bloodfang hood went for 10dkp last time
Man, molten core has been so sweet, started guild runs now, got Giantstalker's Gloves, Giantstalker's Leggings and Eskhander's Right Claw =D
hows yours going guys?
BLOODFANG HOOD 10DKP?! wow nice man, why? lol
isnt min 40, or differ for you guys?
probably cause the guild he got in has ony on farm status and kill her pretty easy. depends how many times the hood has dropped.
we've had it drop 3 times and have 7 regular raiding rogues.
same as we have had brutality blade drop 3 times but they gave it to a pali last time as i was at work so the 2 other rogues there got screwed.
been working when the guild goes to MC/ony so i'm falling behind them on gear.
ah yeah sucks hard, bidding on stuff is so hard for hunters... x_x i want weapons to you know!
no weapons for you! especially now that im combat spec due to all the lag.
btw, happy halloween :P
