Just want to know what's everyone opinion on engine swap from RB25DE Neo to VQ30DET Neo? Do you think that will fit (since this is the engine that they are running on JGTC Skylines - except for the fact that it is VQ30DETT)?
VQ30DET Neo is in use on Nissan Gloria, and Cima.
SPEC:
VQ30DET NEO
・Power:206kW (280PS)/6000rpm
・Torque:387N・m (39.5kgm)/3600rpm
Of course the 206kw power figure might not be true, since it's Japanese limitation.
https://www.sau.com.au/forums/topic/59546-vq30det/
How much does RB30DE puts out?
One good reason to go with the VQ30DET is the configuration. Being a V6, it willl distribute the balance toward the firewall better. I don't know about side ways though. It seems there isn't too much space in the ER34 enginebay.
The daunting thing is that there aren't much aftermarket supports (i.e. ECU, Cams, etc.) that I can find regarding this engine.
https://www.sau.com.au/forums/topic/59546-vq30det/#findComment-1137608
I looked at doing this swap, 3 things put me off it.
1) You will have to adapt a gearbox to suit or pick up a box off a 350z or v35 skyline and a custom tailshaft. That shit is worth close to 8k on it's own. Then you have to sort a clutch for it.
2) Bugger all aftermarket for them atm and i think there are some major differences between the early VQ30 in the cimas and the later one supposedly going in the GTR so any aftermarket support will be limited even in a few years.
3) I'm ****ed if i could find any wiring info or pin outs on the VQ30. And that is what breaks it for me because if i can't find that, i cant get it running.
https://www.sau.com.au/forums/topic/59546-vq30det/#findComment-1138306
I did mean the VG30DET, but the VG30DETT with a set of custom manifolds or possibly a set of VG30DET manifolds leading to a single front-mounted turbo would work as well. I think.
If there is no room for the wide twin-cam heads you could also use a VG30ET. Bit of a step sideways though. But still a very good engine.
https://www.sau.com.au/forums/topic/59546-vq30det/#findComment-1141337
Nissan
Cedric
1995 1996 1997 1999 2000 2001
Cima
1996 1997 1998 2001 2002
Gloria
Leopard
1996 1997
According to http://english.auto.vl.ru all of those had VQ30DET (don't think all were Neos) but all i've found so far are models with AT or CVT no MT as yet.
Edit:
That site shows '99+ Cedrics had the NEO too so there's another source for you.
https://www.sau.com.au/forums/topic/59546-vq30det/#findComment-1141382
    • Out of curiosity, how do officials determine what the OEM ride height and suspension specs are? Do they have a book of truth? I'd think that would be quite obscure knowledge for random JDM cars.
    • This is the check list they sign off on. This implies that adjustable coilovers of the type we're referring to are not a "Variable Ride Height" system. This very much is in the ethos of "I can change the height while moving/while parked without pulling wheels off the car and mechanically doing so"
    • Just an update  ... Put the cat back on no issues with the car running wise ... maybe alittle longer to spoil up the turbo. Still running rich but waiting for my tuner to come back into town to retify the situation. WOT runs fine with the cat.
    • Hi,    Where does everyone buy their stock GTR R32 replacement parts from in Japan preferably? I usually order alot from RHD Japan but sometimes they dont have what I need. Whats the best website for parts in Japan ... as I live in Hong Kong so best ordering from there.    Thanks
    • My post contains the actual truth. Clause 3.2 b.
