I've got one that fell off my car when i was washing it (in the door side bit) haven't got around to putting it back on yet, can't belive its genuine, ill take a pic tonight for you..
but would be interested to see a photo of a genuine one.. and where its located
I'm sure R33 GTR wheels are 17x9 ?
http://www.gtr.co.uk/html/technical/r33.asp
Well there you go - While a UK site, seems fair enough. So just do one up on your 'puter same as sample, print on "Avery" sticker sheet... done job.
TT
ADR states it should be stuck onto the "B" pillar. I still have the factory one on the as well as the aussie one. If you are worried about being defected why not find another Manufacturers one that fit in with your not to crazy tyre width/height and see if you can buy one. I have done this before just had to carefully cut the other brands name off the bottom and also curve the corners as well.
Neil.
Neil.
PMLOL... :cheers:
  • 5 years later...
sorry to bring up an old topic, but i figured its better than starting a new one.
I've searched everywhere and cant find a copy.
does any one know where i can find a picture of the r33 gtr oem wheel size placard??
or if some1 could post up a pic....
thanks
have you tried Google images? you may be able to find one on there somewhere. I have a dodgy compliace one sticky taped inside my glovey on the Vspec II. It doesn't even have the 17 inch size on it! only the normal 16inch GTR and the GTST sizes on it! I need to find a R32 GTR VSpec II one... good luck
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
