1989 R32 GTS-T Type-M (RB20DET – Silver Top)
5 Speed Manual
Black
88889Km's
A.C.T. Registration until September 2005
The car is pretty much stock only with minor modifications
and has never been boosted past factory settings.
Used as a daily driver and gets very good economy for a turbo powered car around 400-450km per tank
Trust Air Pod
Rear Strut Bar
Power Steering
CD Player
Climate Control
Electric Windows and Mirrors
3 Point Immobilizer and Alarm
Remote Central Locking
Side Skirts
Rear Spoiler with brake LED
4 New Speakers - front has splits
Aftermarket Springs - not known as they were fitted prior me owning the car
Genuine Skyline floor mats
Interior is good with no marks or rips on the seats
Interior console has been painted grey.
Stock Mags
Tyres still have about 80% tread
New Water Pump
New Timing Belt
New Radiator
New Thermostat
Last Service was done @ 83390km
- Spark Plugs
- Gear Oil
- Replaced power steering return lines
- Penrite Oil
- Oil Filter
- Fuel Filter
- Transmission Fluid
Located in Canberra
For pictures go to www.users.bigpond.com/adam_stewart
Interested email me - [email protected]
$12,000
Only willing to swap if you have an manual R31 skyline. P.M. or email me for more details on a trade.
I am the first owner of the car since it was imported into Australia
https://www.sau.com.au/forums/topic/59983-1989-r32-gts-t-type-m-12500/
is the car still for sale?
if u r willing to sell it for $11000 cash give me a call
will come down to look at it
No.0431331341
email- [email protected]
I'll get back to you on that.
Still having at least 2 people per week enquire and look at the car, so I figure it is going to sell i'm in no hurry to sell it so I figure I can hang out for the best price.
Car is under offer from 2 people for $12000,
It will be sold for this price if the buyer/s doesn't pull out.
No deposits taken first in with the money gets the car.
This is one of the cheapest R32 you'll find also NON-Modifyed fot the car hasn't been pushed past factory settings.
If you are interested you will only have a couple of days to either P.M. or email me
[email protected]
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
