1989 R32 GTS-T Type-M (RB20DET – Silver Top)
5 Speed Manual
Black
88889Km's
A.C.T. Registration until September 2005
The car is pretty much stock only with minor modifications
and has never been boosted past factory settings.
Used as a daily driver and gets very good economy for a turbo powered car around 400-450km per tank
Trust Air Pod
Rear Strut Bar
Power Steering
CD Player
Climate Control
Electric Windows and Mirrors
3 Point Immobilizer and Alarm
Remote Central Locking
Side Skirts
Rear Spoiler with brake LED
4 New Speakers - front has splits
Aftermarket Springs - not known as they were fitted prior me owning the car
Genuine Skyline floor mats
Interior is good with no marks or rips on the seats
Interior console has been painted grey.
Stock Mags
Tyres still have about 80% tread
New Water Pump
New Timing Belt
New Radiator
New Thermostat
Last Service was done @ 83390km
- Spark Plugs
- Gear Oil
- Replaced power steering return lines
- Penrite Oil
- Oil Filter
- Fuel Filter
- Transmission Fluid
Located in Canberra
For pictures go to www.users.bigpond.com/adam_stewart
Interested email me - [email protected]
$12,000
Only willing to swap if you have an manual R31 skyline. P.M. or email me for more details on a trade.
I am the first owner of the car since it was imported into Australia
https://www.sau.com.au/forums/topic/59983-1989-r32-gts-t-type-m-12500/
is the car still for sale?
if u r willing to sell it for $11000 cash give me a call
will come down to look at it
No.0431331341
email- [email protected]
I'll get back to you on that.
Still having at least 2 people per week enquire and look at the car, so I figure it is going to sell i'm in no hurry to sell it so I figure I can hang out for the best price.
Car is under offer from 2 people for $12000,
It will be sold for this price if the buyer/s doesn't pull out.
No deposits taken first in with the money gets the car.
This is one of the cheapest R32 you'll find also NON-Modifyed fot the car hasn't been pushed past factory settings.
If you are interested you will only have a couple of days to either P.M. or email me
[email protected]
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
