Hey Everyone!!! Please Check Out This Charity Cruise!!!
  • Replies 121
13G is a mate of mine and i would pick his car over any car that was there and you would too if you knew the amount of work in it...
and it's not a 20B at all it's a 13G thus the plates saying 13G....
the 13G is a mazda triple rotor race engine for those who don't know...
intresting
hey guys.... glad to see you out there.... it wouldnt have been the same without the skylines!!!
an enjoyable day was had by all exept for some of the tards doing grassies and stuff....
I believe in total we raised $987 or around that... not much but its something!!!
If you guys want pics from the hot4s site let me know ill post up links...
So yeh who was who on the day. Lets match SAU usernames to the skyline owners i met on the day. I'd like to atleast know the fellow Newcastle skyline owners.
As far as i know there was:
Chris - GTRUSH - OohArrGTR
Chris - NYL 83R - NYL83R
Chris - Rs turbo - ???????
Josh - Black r32 gtst - ???????
Joel - FR33SH - fresh
Ryan - White r33 gtst - ???????
??????? - ???????? - Wizard2k
Myself - UH OHH
Myself - UH OHH
i'm in the white r34 someonwhere in the middle =)
AB ** KA
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
