Hi I have a Apexi AVCR Boost Controller for sale. It's brand NEW, the box was only opened to inspect that everything was in it. It is absolutely spanking brand new.
$490, as I want a quick sale. Located in Victoria Eastern Suburbs, Pickup very much preferred. Thanks
