Traitor! haha nah good luck down the goldy! By the way your car looks sweet, haven't seen it in the flesh until last thursday with the new front bar, looks the goods. (nice flat shift near macca's hahaha :)), I was in the black/bog 180sx with adam. :)
yea moving to goldy...im not a traitor though :). I didnt flat change next to maccas, just changed quickly and the wheels spun, I wouldnt bother flat changing my clutch doesnt love me anymore...:) Im down on Friday so i can be part of the l337 //GC crew lol...cya then cyrus
LOL....darren...mat was talking about MATT's car...its a white 33 with 33NIZ plate on it and has gold rims and HUGE HKS exhause...i saw this one on the flesh too ages ago and tried to cruize along but was kinda late...so i head home...it's pretty schmic i must say.
how did you go with the sale by the way matt ? i guess you're keeping your line eh ?
hey darren...i know the white 33 you're talking about..the one with veilside kit and front mount with chromies..saw that parked underneath landmark resort a few times..i wonder who owns it though ? and yeah...i work at the Wok as the chef and the other guy was my apprentice brother.
and u mat....still haven't seen your car about man...im not to sure but i might have seen it parked in front of sacarys one nite though...must have been a week ago.
had a few offers...one guy wanted an racq check and if it didnt come up 100% clean he didnt want the car so im like hmm, i'll tell you right now it wont come up clean no import will with racq. But i dunno, kinda lost interest in selling it, i've spent money on fixing all the problems, what small ones there were. It will probably be up for sale once i move...i just really needed a car over the past month so i didnt want to sell it before i moved. Dont know what ill get next but i'll stay in the nissan family and probably in the skyline family :)
yea moving to goldy...im not a traitor though :D. I didnt flat change next to maccas, just changed quickly and the wheels spun, I wouldnt bother flat changing my clutch doesnt love me anymore...:D Im down on Friday so i can be part of the l337 //GC crew lol...cya then cyrus
Refer to strutto's "//GC Initiation" thread :P, 200mph+ roof rides for you!!! ;)
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
