C110GTR: That R33 with R34 face is from Uras and just the front fenders alone cost 41,000 yen (almost A$500)... factor in R34 headlights/bonnet/Uras R34 front bumper, and you're looking at another A$1,500 (A$2,000 total) *without paint*... bear in mind these are just guesstimate prices (new parts) and would depend largely on how many used parts you can find.
Similar prices for the Fairlady Z, but I think the 180SX/R32 conversion would be cheapest. I think a guy in AU has already done the 180SX/R32.
**Edit: the guy in AU did a S13 Silvia/R32
https://www.sau.com.au/forums/topic/60683-halfcast/#findComment-1150305
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
