mine is set to 7850rpm.
I have an aftermarket ECU where you can set the rev limiter, and its interesting to see because its set at 7850rpm, but the tacho will go past 8000rpm, meaning the tacho obviously doesnt read 100% true...
I know people who have set their rev limiter to 8,200 on RB20s... but i dont see the point in doing that, 7850rpm is the stock rev cut, so i just leave it there =)
https://www.sau.com.au/forums/topic/60745-anyone-who-knows/#findComment-1153215
