r32 gtr for sale
if anyone is interested in a 89 gtr with a shit load of gear on it give me a call
parts include:
fully rebuilt motor
motor is at the shop getting full rebuild ($9000)
hks to4r turbo($5500)
hks gt waste gate($2000)
hks high mount manifold ($2500)
hks cam gears
hks turbo timer
hks 105mm think intercooler ($2000)
hks plumbing
nismo regulater
greedy electric boost gauge
greedy electric exhaust temp gauge
greedy twin pillar mount
trust twin airflow intake
trust air filters
apexi power fc($1000)
apexi boost controller
brand new drift r 18x9 mags($2500)
12 months rego
twin plate clutch (just rebuilt 0 km) ($1200)
80 mm exhaust
bilstien suspension (lowered)
red in colour
fully polished motor (top half)
pager alarm system with remote start($1500)
engineered
tinted windows
tomei cams
tomei head gasket
n1 oil pump
n1 water pump
vanolia forged pistons
ported head
matched ported manifolds
recondition head
recondition front diff
fully balanced
shot penned rods
arp rod bolts
$38000 phone or sms on 0402919977
http://www.skylinesaustralia.com/fo...achmentid=19168
will consider trade
https://www.sau.com.au/forums/topic/60766-r32-gtr/
http://www.skylinesaustralia.com/forums/at...achmentid=19168
http://www.skylinesaustralia.com/forums/at...achmentid=19169
http://www.skylinesaustralia.com/forums/at...achmentid=19170
Fixed the link up for you (your link was missing the bit in the middle when clicked on)
Nice clean engine bay, good luck with the sale~
https://www.sau.com.au/forums/topic/60766-r32-gtr/#findComment-1156379
it made 380 hp at the wheels before i built the motor on a stock computer running 18psi
the motor is now built for 28 psi and 8600 rpm and will have 500 + hp at the wheels.
the motor has only 950km on it so i have not finished running it in yet or got a time slip. sorry guys. i will garranty that it will have 500 hp at the wheels or will knock $1000 off for every 10 hp under 500.ps the car is in tamworth but will travel to meet anyone who is interested or will pay for air fare
https://www.sau.com.au/forums/topic/60766-r32-gtr/#findComment-1162383
I'm looking at 17K for mine, I will be getting pics of the car tomorow. It has the looks, and the go to back it up.
But thinking more about it, I don't think I would be able to come up with the extra cash needed.
But GL with your sale, very nice car!!
https://www.sau.com.au/forums/topic/60766-r32-gtr/#findComment-1177302
Will consider trade.
ok guys i am willing to accept any reasonable offer.
the toy has to go to make way fo a house
Why would you consider trade if you need to sell it for a house? Wouldnt you want to sell it to get the most amount of money, not a new car & much less money.
Awesome car anyways good luck with sale.
https://www.sau.com.au/forums/topic/60766-r32-gtr/#findComment-1188318
