G'day, how is everyone?
Just signed up. I own a black r33 gtst, number plate hicks, maybe you've seen it?
Just wanted to know when theres gonna be another cruise on?
seen you guys last friday night I think, looked like fun.
Also, anyone with an r33 gtst here pulling mid to low 13's.
i've got a 3'' turbo back exaust with dump pipe and hi flow catt,
custom front mount, trust air filter, s-afc and 14 pounds of boost. apparently I should be able to run 13.5ish but I can only get low 14's! only been down to motorplex twice. Think its my lauches,
any tips?
https://www.sau.com.au/forums/topic/6098-cruizing/
yeah I been motorplex twice, first time I had better better times than last wednesday. think it was the weather though.
how should ya launch em?
anyone else's r33 goes click, click, click, click, click, click, click,
from the air con vents when you start her up?
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92118
used to do on mine but I fixed it! but it's pain in the ass I tell ya! you have to take the whole dash a part...
unless you wnat to do that then just put up with it!
if you wanna still want fix it I can give you tips
cheers
Joe
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92153
Get some susupension bushes m8 appaerntly they help with traction off the line quite alot. U get less axle tramp and that kinda stuff so u can really throw it off the line. Do a search for 'pinapples' and u should find something. :D
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92243
Hicks, your black r33 looks incrediably like a r32 to me. Maybe I'm going blind. To run into the 13's you need a low 60 foot time, around 2.1-2.3, which means you need good off the mark traction. Whiteline make a diff craddle kit, its 4 poly-urethene bushes that adjust the rear craddle for maximum traction. Also a good set of tyres, dunlop f901's or sp9000's will do the trick and depending on your rim size. If you've got a nice set of 17x9" deep dish rims you can stretch some 255/35 or something over them, maybe 235/45. you want something with a fair amount of sidewall for flex when you launch. btw: I've only got a cat back exhaust, electronic boost controller set to 0.8bar, hks pod filter, heavy duty clutch and a set of 225/55 r16 dunlop sp9000's and I ran a 14.11 wednesday night just gone. Rev210 (dave) has got a turbo back exhaust, running around 8-10psi boost and he ran a 13.8!
Rob
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92273
nah, its deffinetly an r33. The only difference on mine is that I have had the rear nissan badge(boot lock) removed and filled over. Some tosser ripped it off!
My rims could be a problem, there 245's but theres not much side wall as the rim size is 19''. Looks good though!
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92277
i think i saw you on leach hwy near risely st a couple of times, the bootlock has been filled, and its still got grey primer right?
I have seen 2 different black R33s there, but i definately saw 'hicks' i could be wrong about the primer though.
Nice car all the same.
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92488
mine does that.. sometimes when i turn the car on it does so and the climate control wont turn on until its all clicked out.. im thinking its the air directional doozies or some crap *shrug*..
if it aint broke.. dont fix it.
Shaun
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92491
    • I might do a few more high temp bed ins as described here.  I have a nice quiet 80kph road right near me.  How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
    • I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
