  • Replies 305
hehehe... glad you enjoyed it! :D though you hammered it after the ferry!!!!
hope you all enjoyed the cruise!! i know silv thought the way up to wisemans was boring!! hrmp!!! the alternative was old pac both ways or boring old northern road! so :)
sorry about the whole food thing!! i think the bush burger place was doing a better job getting everyone food!!! hope everyone got to eat something!!!!!
Anyways.. was an awesome day!! i didn't expect so many cars! I ran out of maps! but i think everyone got there in one piece! :D
