Rezz,
I need your help. I've seen a nice hr31 gts-x for sale in Japan. I wanted to know if you knew any places that will ship it to Australia for a good price. I need to find out a.s.a.p cos the auction finishes tonight
regards
Andrew
https://www.sau.com.au/forums/topic/61384-rezz/
Rezz,
regards
Andrew
Have a look at these guys. I'll be using them to take a car to NZ in late May. They also service Australia.
http://www.kiwicar.com/
IG
https://www.sau.com.au/forums/topic/61384-rezz/#findComment-1159739
oh sorry mate, I didn't realise there was more than one Rezz.
I was asking you for help mate, your the super moderator in Japan right? :rofl:
Btw, I found a cheaper hr31 gts-x for only 10,000 yen which finishes tomorrow night. I have the cash, and what i'm looking to do is get the person who ships it a bonus for picking up the car and delivering the cash, then shipping it or.... arrange for the seller to drop it off, one of the two. But i'm so serious about this, I really want it
So if you can help it would be greatly appreciated, if you want money that's fine
Regards
Andrew
https://www.sau.com.au/forums/topic/61384-rezz/#findComment-1160489
I think you'll find it easier to go with an Importer ...
I was thinking doing the same but its not just buying the car there's more to it than just buying a car.
You have paperwork to deal with then you need a contact or reliable person to organise the car to be delivered and then get sent to shipping port, then more paperwork plus and organise it when the car lands on OZ land, then compliance which should be easy as it will be under the 15yr rule and you can do it yourself...
But if you have experience importing a car before then go for it I might even ask you to do mine LOL
Good luck anyway
https://www.sau.com.au/forums/topic/61384-rezz/#findComment-1160613
Good luck anyway
Yeah, I know there is a lot of paperwork. But I didn't want to have to spend $1k on an importer to do all the paper work
I know there will be import duties, GST (10% of purchased item is 10,000yen is about $13aus.) and government stamp duty on top of the shipping prices. Do you know a rough cost to get from Jap to Bris/aus?
Is there anything more i need to know about importing?
https://www.sau.com.au/forums/topic/61384-rezz/#findComment-1161276
Mitsui OSK Lines
http://www.mol.co.jp
Tel: 81-3-3587-7021
Fax: 81-3-3587-7706
NYK Line
http://www.nykline.com
In Japan:
Tel: 81-3-3284-5151
Fax: 81-3-3284-6361
In Australia:
Tel: 61-(02) 9248 1000
Fax: 61-(02) 9290 2779
Kiwi Car Carriers
In Japan:
Tel: 81-(0)47-471-1411
Fax: 81-(0)47-471-1212
In Brisbane, Australia:
Tel: 61-(0)7-3839-3373
Fax: 61-(0)7-3839-3396
Here's the main 3 carriers we use at J-Spec, I've included the telephone numbers in japan, they have english speaking reps who you can talk to. They might deal direct with public, or they might refer you to a local agent who can do the shipping booking and customs, deregistration etc for you.
I spoke to the guys here if they could do it for you for a lower rate or something because they're not actively searching for a car for you or getting a mechanic check or anything, they said they'll have to see what would be involved before they can give any quotes, so I'll let you know.
https://www.sau.com.au/forums/topic/61384-rezz/#findComment-1161654
thanks Funky, The auction finishes at 9pm qld time. I have to know before I bid as I don't want to be stuck.
Should I bid anyway and take the chance?
kiwi car carriers quoted me $1300aus for shipping.
https://www.sau.com.au/forums/topic/61384-rezz/#findComment-1161695
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
