1997 r33 Gtst Series II
Price $19,900
Kilometres 48,000
Pearl Silver
5 speed Manual
Manual Turbo r33 gtst Skyline with Upgraded Bodykit, immaculate condition, low km's and stock standard. This skyline has all the added features of a the series 2 skyline. Body and interior in immaculate condition. This vehicle was manufactured in 1997. Comes with 6 months registration. Price is firm.
Contact 0401698552 or email [email protected]
http://www.carsales.com.au/pls/carsales/!c...hicle_id=136585
https://www.sau.com.au/forums/topic/61471-r33-gtst-manual-1997-series-ii-19900/
I will freight this car to Adelaide or pay for your airfare. If u r serious ... I'm sure we can work something out :rofl:
Yeh but the only thing that stops me from doing this is the hassle of registering it here. Doesn't the car have to go through a complete check?
The car is already registered in Queensland. From what I'm aware of, when it gets to Adelaide, you need to get a RWC for it and it can be trasnferred into your name. Not too tricky. I'm sure it can be worked out. Call me if u want to work something out.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
