  • Replies 175
I will be there cathing a ride with daler32 im no taking my 33 simply becasue im screwed for that stupid speeding thing i did and i dont want to get anything else happed before i go to court knowing my luck get caught for stopping 2 close to a corner or something and that has happed before lol.
See you at the yatala pies carpark at 7:30 gold coast people.
And to all other we are not dumb gold coast people we are just courteos to others who may want to suggest where to meet:)
oh if anyones after a uhf dick smiths sellin two uniden uhfs in a pack for 58 bucks
http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/D1804
Buy these only if you wish to have all the range of leaning out your window and yelling at the other car.
They are seriously crap.
Spend $150 and buy a 2W, "AA" (not bloody "AAA") battery powered Uniden. Or if you feel like splurging, buy the battery pack to go with it.
Here is direction taken off whereis.com.au for those of you that are from the coast
Start at PACIFIC HWY, UNDERWOOD
19.90 km 19 Mins
Continue along SOUTH EAST FWY, UNDERWOOD
4.18 km 3 Mins
Continue along GATEWAY MWY, EIGHT MILE PLAINS
424 m 1 Min
Continue along GATEWAY MWY [RAMP], EIGHT MILE PLAINS
159 m 1 Min
Continue along GATEWAY MWY, ROCHEDALE
12.55 km 10 Mins
Turn left at WYNNUM RD, TINGALPA
1.98 km 2 Mins
Turn left at RAMP > CREEK RD, CANNON HILL
237 m 1 Min
Finish CREEK RD, CANNON HILL
39.43 km 38 Mins
Course you can come yotis :)
I think the gold coast people need to decide on a meeting spot! Or I'll make one for you ;) Yatala Pies at 7:30 leaving at 7:45. There ya go, head up the freeway, take the gateway motorway exit, follow along until you get to the Wynnum Road exit. Turn left at the bottom onto Wynnum Road, follow along until you see a big shopping centre carpark on the left, turn left at the intersection with the BP and Red Rooster at opposite corners. Turn second left AFTER the first set of lights and that's the Bunnings carpark.
There you go, all done.
And that is different.... how?
:D
Hello all, I will be there. This is my first post on the forum (after many weeks of reading) so I don't really know anyone. I am happy to meet other owners etc. I have a completely stock Series 2 R33 GTS-T, so please be nice and don't give me too much stick...because when I say my car is stock I mean stock! Hope to see you all there.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
