hey i'm thinking of getting 19's with the following tyre specs:
225/35/19
will they fit under the lowered cef easily? I should be able to have a test fit but just want to know if it's worth trying.
will they still be legal?
cheers!
Luke
https://www.sau.com.au/forums/topic/61625-rim-tyre-size-on-cefiros/
FAT.
Got pics? :)
I'd say you need to roll your guards atleast. Probably spacers at the front. And a "fat" offset.
My rims are 18x7.5 (or 8.5) and the front needed 20mm spacers to fit (the guards are already rolled).
They wear 225/50/18 I believe. (Could be 235/45/18 can't remember).
I reckon I could fit 19's with 35 profile so if you want to test fit on a cefiro with spacers and rolled guards I volunteer mine (save you rolling your guards only to find you cant put the wheels on). I'd love to see my car with 19's (the 18's don't look big enough ehh heh so for a dumped look if I could I'd get 20's).
As for legality without engineering I don't know. I never was able to work out the proper thing (even after reading the RTA document about it) but... Duncan explains it pretty well here.
The actual RTA docs are here - http://www.rta.nsw.gov.au/registration/dow...si/vsi_dl1.html
And the wheel/tyre guide is here - http://www.rta.nsw.gov.au/registration/dow.../vsi09_rev4.pdf
Good luck :P
Whether the rims fit will depend highly on the offset and width of the rims.
Given the tyres you are planning on using, i'd guess they are 8 or 9inch. If you get the correct offset, then they should fit fine with some guard rolling..
Given the tyres you are planning on using, i'd guess they are 8 or 9 inch. If you get the correct offset, then they should fit fine with some guard rolling..
the rims are 7.5 wide, with either an offset of ET20 or ET42 - these are the manufacturers specs but the guy with the wheels hasn't checked - they were on an R31 skyline so does anyone know which offset it is likely to be?
cheers!
no pics yet cc :)
this is what i have gathered from rta site and another forum.
stock wheel size ...according to my cefiro (which has a wheel placard) ..is 15 x 6.5 wheels with 205 /65/ 15 tyres.
legally without a engineering certificate u can only go 1 inch wider and a max of 15 to 20 mm larger in total wheel and tyre diametre size......so u could have 18s on but lows profile tyres of 35 or 40 or something like that ....check it againt one of those tyre size calculators....this is this is one
the rta website says for enineering ....they can only go up to 2 inchs wider that the extra inch i think ...which would be another 3inchs to the width of the stock rim ......
thats how i read it anyway...
Tire Size Comparison
current stock wheels
Specification 205/65-15
Sidewall 5.2in
Radius 12.7in
Diameter 25.5in
Circumference 80.1in
new wheels
Specification 225/35-19
Sidewall 3.1in
Radius 12.6in
Diameter 25.2in
Circumference 79.2in
I recently got rims on mine with no spacers.
Front and rear have been rolled slightly
18 x 7.5 (offset +32) on front with 225/40/18
18 x 8.5 (offset +32) on rear with 255/35/18
I start to get the fronts rubbing on full lock, and not much room at the rear.
They seem to be a pretty perfect fit.
oOOo kursed is getting dubs on his virgin ceffy!
i have 18 x 7.5
post pics of the wheel, or type,
i want new wheels,
just so i can interchange them for how my pimp lean is feeling...
i want some mesh high polish steel with the lowrider gold spinner in the centre =) drooool
put it this way pimpdat you wouldn't wanna lower your car too much with 10 inch on the rear, especially with 9 inches on the front, but if you're going for the "pimmped out" look then they'd look quite porngraphic on a cefiro
i had 17x10 wheels on my cefiro for motorvation this weekend
they had a gtr offset(i have 5 stud conversion)
they was just tooooooooo wide on the rear and my guards are rolled slightly, i had to dial heaps of neg camber to get them to fit
but on the front it was fine the offset allowed for everything to clear and they only stuck out a little bit
so the offset is the most important thing
Also just to throw a spanner in the works... I think you need to make sure the wheels also clear your brakes, as I know my front ones without spacers, I cant even put the nuts on the wheel properly. But umm, 19s dude... Think about that, they arent really a practical size wheel.
dubs are 20's dude!
yeah i know! but 19's!!!! argh. spoof. well basically i found a set for a good price and i am doing a bit of cefiro group research, so these opinions are welcome. unfortunately they are not in nsw so i need to go somewhere that stocks the rims and trial fit them... i think tempe would have em. I may just end up with 18s but the wheel arches are so wide on the cef i think they will look like 17s
pimp dat those rims are fkn FATTER than kirstey alley after a pie eating contest.
good luck getting your ride lowered over those though.
I have 235/40/18 on mine heres a pic for your veiwing enjoyment - I just threw these on and didn't roll any guards, they don't scrub at all - but there is a possibility that it was done before I got the car.
these are the rims i thinking of getting. +5 and plus +6 offset, WTF does that mean i have no idea i am getting wide body front but dont know about the back. are these going to be hard to fit?
sorry for changing topic a bit kursed
man they are nice :D they are the ones i was going to get for my R33, GMAX do some here in Aust. but so far i haven't found a 4 stud option
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
