SE QLD Skidpan ....................
ok its confirmed.
28th July, Mt Cotton driver training centre. Arrive at 7:45am if participating.
$70 per person.
12 spots
First in best dressed.
Spectators welcome.
Its totally sick. Instructors, diesel and water on the track. wont really root your tyres. Ive been twice before.
Bank Account Detalis for payment.
Bank : Credit Union Australia
account name : Paul McConnell
account number : 30322985
bsb number : 804050
Let me know when you pay. 32621860 and 0411870159. You can post me a cheque also. If you have any questions just call me.
I know a lot of people that want to go, but until i see money, nothing happens. I just put peoples names down last time without payment but it didnt work out too well with some stuff happening on the day.
1. slip
https://www.sau.com.au/forums/topic/617-se-qld-skidpan/
  • Replies 51
:sly: :boobs:
THE COST FOR THE DAY IS $70 each
(1) Slip R31 (Paid)
(2) Kenn R34 (Paid)
(3) Gary R33 (Unpaid)
(4) Birty R32 (Unpaid)
(5) Cam R32 (Unpaid)
(6) ?
(7) ?
(8) ?
(9) ?
(10) ?
(11) ?
(12) ?
Squizz it will be the same as last time, 4 to 5 hours ok :cheers:
:burnout: ;)
https://www.sau.com.au/forums/topic/617-se-qld-skidpan/#findComment-16819
(1) Slip R31 (Paid)
(2) Kenn R34 (Paid)
(3) Gary R33 (Paid)
(4) Birty R32 (Paid)
(6) Squizz R32 (Unpaid)
(7) Revlimiter Boy R32 (Unpaid)
(8) ?
(9) ?
(10) ?
(11) ?
(12) ?
Nismo boy, they teach you to drift :uh-huh:on the skidpan. Thats pretty much it, you have them in the car for 1 or 2 sessions (or more if you want) they can drive your car to show you, and then you go sick. :shake: Pay me asap to get a spot. They will all be taken before the day.
https://www.sau.com.au/forums/topic/617-se-qld-skidpan/#findComment-17789
1) Slip R31 (Paid)
(2) Kenn R34 (Paid)
(3) Gary R33 (Paid)
(8) MRE (Unpaid)
(9) Paul Baltzer (Unpaid)
(10) ?
(11) ?
(12) ?
squizz have you deposited the money yet?
https://www.sau.com.au/forums/topic/617-se-qld-skidpan/#findComment-24647
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
