SE QLD Skidpan ....................
1) Slip R31
(2) Kenn R34
(3) Gary 2.8 tonne 4wd. (dont ask)
(4)
(5) Cam R32
(6) Squizz R32
(7) Revlimiter Boy Pete R32
(8) Luke R31?
(9) Marc R33
(10)MRE R33
(11)Scott R31 GTS1
(12)
righto, this is rockin along nicely.
People. Mt Cotton Rd, look in a refidex, the training centre is clearly marked out, its very easy to get there.
BE THERE at 7:45am, really.
Gates will be closed after we start, bring food and drink, there is water available there, but ya need some food to eat (well i do anyway)
mmmmm 1 week :D
  • Replies 51
Yes, Sunday 28th July, 7:45am, Mt Cotton Driver training centre, Mt Cotton Road (in mt cotton, or loganholme or something)
cam maybe someone from duel would want to go on the pan?
if anyone wants to correspond about the pan to me, please call my mobile 0411870159 as im rarely online (no net at home)
Hey Slip.
Well, I just got back from Adelaide (yes I called you) and found out that my car won't be ready so.... I'll still pay the cash as I promised.
I wish I could take mine out but its just not an option. I'm sure it will still be a hell day!
By the way, anyone keen for hitting the clubs / pubs on Friday night????? I am hell keen and so r a few others so let me know if you want to meet up
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
