Ok, as I posted last week my car went into 101 Motorcafe on monday the 10th. I must say these guys were great, they kept me informed of everything they were doing and told me if I was wasting my money (i.e no you don't need a fuel pump yet.) they looked after my car and did a great job of installing the parts and my car now runs so much better. only issue was it took a day longer then expected due to them waiting on a part. I have no hesitation in recomending these guys to anyone. if anyone is looking for a mechanic around the brisbane/ logan area give these guys a call and see what you think.
https://www.sau.com.au/forums/topic/61716-101-motorcafe/
I've actually heard a fair bit of positive stuff about these blokes, and my/mates mechanic uses them for tuning from time to time (he normally sends stuff up to Toowoomba) so they must be pretty good.
How was their pricing? Thats basically the only bad thing I've heard that they were over priced, but other said they were good.
https://www.sau.com.au/forums/topic/61716-101-motorcafe/#findComment-1165039
The Pricing was great bout $800 cheaper then every where else I went.
https://www.sau.com.au/forums/topic/61716-101-motorcafe/#findComment-1166001
is that the place with the pink waiting room that sells cuuppuchinos and turns into a bar at night time with a crankin loud stereo?
Yep thats the one
mechanic with a cafe and tunes.....how good is that?
https://www.sau.com.au/forums/topic/61716-101-motorcafe/#findComment-1166657
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
