Replacing your pushrod tube oil seals in your LS1 V8 (a must read)
Pushrod Tube Oil Seals
Leaky pushrod tube oil seals are a common cause of oil leaks on the VW air-cooled engines. To fix the leak, you have to remove the pushrod tubes and replace the seals on both ends.
It's not a technically difficult task, but it is time-consuming and will try your patience. It will be easier to do the job with the rear wheels removed.
NOTE:This procedure applies only to the Type 4 engine. To replace the pushrod tube oil seals on a Type 1 engine is much more involved, since the cylinder heads have to come off.
To remove the pushrod tubes,
1) Remove valve cover -- get your big honkin' screwdriver under the bail and pry it down (don't pry it up. You'll regret it. Ask me how I know).
2) You are now faced with your rocker arms. Note that there is a thin metal wire spring thing that is very oddly shaped and goes the length of the head, fitted under the rocker arms and holds the pushrod tubes in place. Pay attention to how it goes because you will need to know later. This is another reason for doing only one side at a time so you can reference the other side for reassembly. Anyway, loosen the rocker arm nuts a bit so you have enough slack to get that spring out. Try not to bend it up too much.
3) Get a clean paper towel or something similar to keep all the parts on. Put the spring on the towel. Now remove the rocker arm nuts and washers and put them on your towel. Don't lose 'em. Pull the rocker arms off the studs and be careful as they will want to fall apart as soon as they are free from the studs. Put them on the towel next to each other like they are in the engine. This is one of those jobs where you want to avoid mixing stuff up.
4) Remove a pushrod (I do these one at a time so I don't get the pushrods mixed up. Just pull it right out. Sometimes they are full of oil and surprise you. Lay it on the paper towel, make sure it's straight by rolling it. If it's bent, time for a new one.
5) Remove pushrod tube. You do this by twisting/pushing/pulling it out through the cylinder head. Many say not to use pliers on the tube but if you use pliers and squeeze lightly (so as not to crush the tube) you'll be OK, I used pliers when I did it and they're MUCH easier to get out that way. Just be sure to squeeze very lightly. You usually need to set up a twisting motion to break them free and then pull back firmly but gently and pull the tube out through the head.
6) Clean up old tubes or replace them. Use parts cleaner, like brake parts cleaner or carb cleaner. Get all the crud off the tubes, you may find that they are not supposed to be black. You may also elect to purchase a complete set of new pushrod tubes. Remove the old seals from the tubes if you are reusing them. I usually get them off by getting a screwdriver blade under the seal and prying it off the tube.
7) Install new seals. There are two kinds available. One is the stock VW seal and the other is the seal that gets used on the Porsche version of the same engine. Buy the expensive Porsche version. Word is they will outlast the VW seals quite well. You will need 16 seals for the job and the seal for the case end of the tube is smaller than the seal for the cylinder head end. So you should have 8 of the large seals and 8 of the small.
8) Clean up the sealing surfaces on the cylinder head and the engine case. Use a paper towel moistened your parts cleaner of choice. Be thorough, any dirt on the sealing surface will cause leakage. Take your time and do it right.
9) Repeat with each pushrod tube.
10) Put everything back together. When reinstalling the pushrod tubes, you need to make sure they seat all the way. They don't tend to want to go all the way in by hand. I used a big 1/2" drive extension as a drift and gently tapped the tubes home with a hammer. Be careful doing this that you don't pinch the seals on the head end.
Make sure that you put that wire spring thing back in correctly. It holds the pushrod tubes in place. Again, don't mix up the pushrods, rockers, etc. Also, when putting things back together, you will want to make sure that the pushrods seat correctly in the lifters. If you twist them around by hand you can just feel them slip in where they're supposed to be. After you're done, put new valve cover gaskets on (don't use sealer, just a thin coat of wheel bearing grease on both sides of the gasket). If the sealing surfaces for the valve cover gaskets on the heads are rough, it is wise to take some steel wool and use it to smooth the cylinder head surface out. This will stop those pesky valve cover gasket leaks. If you have solid lifters, you will need to adjust the valves after this operation (that's another whole procedure, but is written up well in Muir). Some say if you have hydraulic lifters you also need to adjust but I've seen it done without adjusting and it's been fine.
I hope this helps someone else as much as it helped me. If you need further instructions please pm me or reply to this thread.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
