Hey , my Cef has s13 JIC coilovers in it currently.
But they coilovers are actually short because they are for an s13.
The coilovers are wound up the highest and the car is 100mm off the ground at the chassis, but even lower with the exhaust!!!
Who wants to trade + moneys for proper Cef coilovers? Cos i want the additional height clearance.
Vic prefered.
JIC coilovers in top condition not leaking.
Yep. thats what I was thinking. The suspension is identical... how else could every other link be the same as S13 without this height issue. My guess is that you dont have helper springs. they will give you the 30mm you require.
JK
I like to use S-13 suspension, cuz there is a lot less spring travel. If you want the proper sized strut a S-14 front is about the same size as a strut designed for a cefiro. The only thing is that you can't use the S-14 rears, they are way too long. I like 12k springs on the front and 10k on the rear, makes for a crappy ride, but it's great for drifting
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
