Hey guys,
before you tell me to read the E-Manage thread in FI.. let me start by saying that I've read it and am familiar with what it can and what it cant do and I have decided if its suited or not to my particular application.. The info i'm chasing is.. who can tune it in Perth? And those in WA has had experience using E-Manage; who tuned it for you, how much did it cost?
kthxbai
:D
https://www.sau.com.au/forums/topic/62111-e-manage-issit/
Fane - indeed.. coz im not aiming for huge power (260-270) for sure so im fairly certain that the E-Manage will have no problems getting me there.. yes i know piggybacks would probably get the same result (SAFC + ITC) but since the E-Manage has become cheaper and cheaper i feel its worth a second look :rofl:
https://www.sau.com.au/forums/topic/62111-e-manage-issit/#findComment-1172662
if my memory is serving me well...... i think xspeed had a red s15 which used emanage and it was auto but had a few probs with it?
adrian :P
yeah Adrian the earlier versions had problems mostly with coilpacks but its been awhile and the latest version apparently deals with the problems in both Nissans and Evos
https://www.sau.com.au/forums/topic/62111-e-manage-issit/#findComment-1175892
Not sure the latest firmware did fix the coilpack problem, as I've still heard of people having trouble. Just play it safe and put the zener diodes in like I did, I put some details in the e-manage thread.
That way you can also drop the trigger voltage down closer to the factory pulse voltage.
It's running fine with my auto transmission, never had any trouble with that aspect.
https://www.sau.com.au/forums/topic/62111-e-manage-issit/#findComment-1175943
Michael - thats nice! what other mods do you have?
Thanx...current mods are Hybrid FMIC,Hi-flowed Turbo,E-manage,Z32 AFM,AVC-R boost controller,Walbro HF pump,JASMA 3.5" CAT back and dump,Apexi N1 adjustable coilovers, whiteline adj. sway bars front and rear and camber adj front,...sitting on the bench...800cc SARD inj, TD06-20G,custom manifold/plenum,dump pipe and fuel rail.
Cheers,
Michael
https://www.sau.com.au/forums/topic/62111-e-manage-issit/#findComment-1176934
my bench is looking nice at the moment....but can we combine plz....i would like your sards and the custom mani and plenum and fuel rail :) hehe
nice figures dood....like i said before....interesting...emanage....
lol...thanx fane ;-) ...wouldnt leave me much on my bench dude, just a huffer that wont get the juice to go....i know where to come lookin'...i is local to you too...but yep often under-rated the E-manage but definitely good for people limited in choice having auto transmissions...but then again wont have my E-manage for much longer if plans work out....will stop whoring the thread now!
Cheers
Michael
https://www.sau.com.au/forums/topic/62111-e-manage-issit/#findComment-1177024
if you are making large changes from the stock mappings it will affect your auto operation to some degree . it may be acceptable to you or it may not
i have had no issues with my auto operation in over 2 years at the above power levels, shifts have always been spot-on and tight, no flaring,nada.....maybe its coz i drive it like grand ma ;-)
rev-limiter wots that...babababa...ohh THAT!!
Cheers,
Michael
https://www.sau.com.au/forums/topic/62111-e-manage-issit/#findComment-1177064
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
