Does anyone know where you can buy a drivers side and passenger side boot kit?
My outer passenger and inner driver side have both started to crack damn it!
Any help appreciated.
thanks
:headspin:
any decent drive shaft place should have the boots, I got mine for my GTS4 in Brisbane from the Australian CV joint centre - about 2 years~ ago they supplied and fitted the boots(inner & outers) to the driveshafts - I took into them for about $70. The driveshaft nut that holds hub is VERY tight and I had to hire a huge socket set so I could get the bugger loose.
I dont know about any 'kits' - if you mean one where the driveshaft doesnt need to be removed, like the steering rack boot kits that you can get.
Check the specs of the grease they use against what nissan recommends in the workshop manual to make sure it is high grade enough, it will probably be better than what was available in 1990~s but check while you're at it. You will have to put grease in one side yourself and fit one boot to diff, the other side just bolts up.
Stephen
You can get them from Nissan but they are about $70 each .
Go to any auto shop and get a universal boot kit , about $12 -15 each , they have the molly grease with the kit . You dont have to remove the driveshafts from the car to replace them .
thanks
:headspin:
  • 3 months later...
I have to replace the boots on mine as well as both sides have split and thrown grease all over the wheel :rofl:
I've pulled both drive shafts out .... can I take them to a CV-joint shop and get them to fix them up? ie. put new boots on, clean the original shafts and put grease in etc?
Thanks ! :(
  • 5 months later...
G'day Jerry,
can you expand on your info for the CV joint boots?
Im going to be needing to do it at some stage soon...
also I need to do the steering rack ones! do you know or have you done it with the repco kit RRB033 I have heard conflicting reports about how good a fit they are with the GTR
would be great to find a way to do both sets of boots for less than a work shop!
thanks....
G'day Jerry,
thanks....
Ben ,
I dont know if you can match the steering rack boots with aftermarket ( i'm fairly sure you would be able to ) .
As for the cv boots , go to any auto shop with a sample boot and they will match it , failing that you can use the universal ones ( you cut to suit ) , there is 4, 2 on each driveshaft . You dont need to pull the shafts off the car to change but you have to release them so you can fit the new boots on . If you never done it before its best to leave it to a workshop as it is a bit of work on the gtr and i dont know your mechanical knowledge .
Why do you say you have to replace them ?Are they cracked ? Are they split ? If they are split you have to do them asap otherwise you get water in the cv's and then you have to replace them as well . The steering rack are not as critical but you should still replace them if they are split .
Edited by wrxhoon
ahhh ok....
mech knowledge is ok, just a hoist would be nice, but I could do it all here as I have now got a nice workshop at home (in adelaide)
as for the boots....
steering is spilt for sure.....
and CVs some grease has come out of a hole somewhere!!!! no idea, cant see it...
but yes they are needing some work!
will look at getting a shop to see to them if they are that much of a bitch!
thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
