ive had my safc II for about 8 months and my car ran great, no probs at all, then about 2 months ago, out of the blue, my car wouldnt idle at all.
sent my car back to the tune shop for a couple of days, after testing everything they could not fault anything. they had to adjust my fuel to +20% at ilde just to get it to idle then -20% off idle just so it was driveable....after a few more weeks my car went back to swap ecu's, no change, then we disconnected the safc and by-passed the wiring and car ran perfect.
any ideas on what when wrong with the safc and can they be repaired ?
https://www.sau.com.au/forums/topic/62318-trouble-with-safc-ii/
I have never seen or heard of an SAFC having a localised problem, runs OK at some RPM's and not at others. They either work perfectly or fail completely (through incorrect wiring).
So I suspect outside factors;
My first point of call would be a dirty AFM. Try cleaning it with brake cleaner.
Second would be a bad connection between the SAFC and the ECU. Removing the SAFC means the connection is no longer there, so that's why it runs OK now. Idle is low voltage from the AFM (input), and a failing connection lowers the voltage some more, that's why adding 20% (increasing the output voltage) overcame the problem.
Lastly, I have seen a faulty alternator/battery (or a big stereo load) cause idling problems. As desribed above, the voltage gets too low at idle. Maybe check the alternator output and the battery just in case.
Hope that helps:cheers:
thanks syd, i found it a pretty strange problem aswell... we did clean all connectors including tha afm so its not that... goode point about the alt voltage, i havnt checked that (will do ) as we have rewired the harness back to normal its a bit hard to do any more checks.... as to my idle problem, it wouldnt idle ie as if the ignition was turned off as the revs dropped down to 1100rpm.... even with the 20% adjustment it was by no means a good idle, very ruff when cold
i find it hard to understand why it ran great for 6 months then bag ... no go
i think i want to find someone with a safcII and plug mine in there car and see if she works, thart way i can sell the safc knowing its not faulty... anyone in perth want to help me ?
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
