I have a front set of brakes for sale off a 95 GTST. Comes complete with calipers and rotors.. Great upgrade for any S13. Im really not sure how much to sell it for..
Brakes are a stock off a R33 GTST and are in good condition.
Pictures have been added:
I am after $400ono..
More pictures can be found at http://www.users.on.net/~ecr33/Brakes/
Please note, everything that comes with the set is shown in the first picture.
https://www.sau.com.au/forums/topic/62360-gtst-brakes/
Assume they are off a '95 R33 GTST.
Please confirm:
- rotor size (296 mm x 30 mm?)
- are they stock R33 units or aftermarket?
- rotor condition? ..... that is usable rotor thickness?
- calipers? ..... assume are the stock R33 Sumitomo 4 piston units ...... with the casting ribs?
A few pics please - would be great to save a thousand words.
Cheers,
Richard
https://www.sau.com.au/forums/topic/62360-gtst-brakes/#findComment-1179384
hi guys,
The brakes are in good working order when i had them on my old car. They are currently at a mates house, i will have to grabe it back off him n take some pics. Hopefully i can do this 2morrow. As soon as i get the pics i will post them up there.
Thanks.
https://www.sau.com.au/forums/topic/62360-gtst-brakes/#findComment-1180401
Pictures added.....
The rotors are rusted, but thats what you get for storing them without usage for a few mths. It all just need a little cleaning, but is in good working order.
Please note, everything that comes with the set is shown in the first picture of the first post.. It will be sold to the person who wants them for $400ono.
https://www.sau.com.au/forums/topic/62360-gtst-brakes/#findComment-1184671
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
