I am thinking of importing a 32 GTR or GTST, and I have heard that the GTR's are prone to "blowing" up due to their age when they get over here and the thrashing they get in Japan??
Can anyone fill me in, and also if you know of any good, cheap, reliable importers in the brisbane area, please let me know.
Cheers, Matt.
https://www.sau.com.au/forums/topic/62478-realiability-of-a-r32-gtr/
The BEST importers as far as i'm concerned are SVI in Virginia, Brisbane. They are reliable, honest, trustworthy and no bullshit in anything they say/do. They're also one of the original importers around, so they know their stuff.
www.svi.com.au or email the owner on [email protected]
i imported my 180SX through them 18 months ago, and just finished importing an R32 GTR through them too!
Theres no way of telling how long the engine/car will last before you buy it... best thing is to budget some spare money to fix things when they break initially, fix them once, and then look after them... as the other thread i just read before this said - the RB engines last a long time when they are looked after and not modified... even modified can last a while when they are looked after.
Just because you can afford to buy a gtr, doesnt mean you can afford to own a gtr.
If money is sometimes a concern, i would definitely go for a gts-t.
A lot of *younger* people i know, are going GTR mad, because they are for sale from importers from as little at $16,000 (pretty rough looking ones), but the maintenance costs on them can be very high.... and they cant afford to fix them when they fcuk up... so they are stuck with a 'cheap' GTR that goes no where, and they cant sell it because they will lose the majority of the cash they have already spent... not a good place to be in.
Dont buy a cheap GTR, spend the cash and get a good one if you go down that path - but be prepared for significant maintenance costs.
GTST is a safe option... maybe u should start at a GTST then later upgrade to a GTR??
*shrugs*
R32 GTRs can be just as unreliable or reliable as any other cars.
So the price range for R32 GTRs at the moment is around $16000-$35000.
Like anything, you buy from the bottom of the price range and you will get a car accordingly.
Remember they were manufactured from 1989 to 1994. If you're really paranoid, try to get a really clean 1994 model. Then you have a car that's *only* 11 years old.
Just don't get a really cheap 1989 thrashed out example then bitch about it.
Hey, my nice clean 89 track battler is still going strong!!! (yes, I believe it saw the track at times!) I bought early - before the rush on the 89's and managed to get a good example for good $$$. Prestige motorsport.
id like to have a beer with duncan. id like to have a beer with duncan cause duncans my mate. :D anyways i think all skylines are reliable and u always pay for what u get. but be awared the more modifications that are on the car from japan the more chance that it will be a shocker. i say buy a full stocker and build it urself
I couldnt agree more i brought a 92 GTR $25k nearly two years ago and have spent a fair bit getting to the standard i want without even modifying it...
So if you buy a 89 model be prepared to spend money on it...
The best scenario is to get an 93 or 94 model but the trouble is finding one and if you are willing to pay 30k plus..
i personally think the its better off buying a later model rather than buying an 89 that needs heaps of cash poured into it...
For 35k, you would be able to get a R33 GTR V-Spec....
Yep sure, it's the concept of natural variation.
The best R32 GTRs may cost more than the worst R33 GTRs. Correct, but missing the point.
Personally I would still have got an R32 GTR if I could afford an R33 GTR because the R33 is fugly.
I really couldn't be bothered reading thru all the posts here, too lazy lol!
But inregards to the original posts:
i think the following applies:
1) you get what you pay for
2) the product reflects the salesperson...
so yeah, go with someone you feel you can trust after talking to them and don't get one car over another 'cause you'll save a few bucks... you'll most likely spend twice what you save in repairs in the end.
I had a 89 R32 GTR imported privately and havn't had a single problem yet... it's a pure dream... but i know people who have had the opposite so yeah...
Good luck with what ever you decide :)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
