hi guys just looking for some good suggestions about a noise thats coming from my car. Its coming from the suspension or from the bushes. I have taken it to for different places and all have given me 4 different answers. i really dont want to spend money on fixing the 4 different things and then find out it was something simple. This is what i was told - ANSWER 1- Bushes are fine but u need to change ur front shocks.
ANSWER 2 - Everything is ok. your bushes are supposed to squeek as they are made from that type of rubber.
ANSWER 3 - Before we look at it we suggest you change all 4 shocks and springs and then we can identify the noise because it is sitting on the bump stops???( which i dont think so)
ANSWER 4 - The front bushes come loose i tightened them and now they should be fine. 30 mins later same noise again.
All these suggestions i have had are fine but the funny thing is this noise on comes in the mornings when it is cold and on cold nights. During the day when it is sitting in the sun all is good and my head is peaceful as i dont hear any squeeks.
Any suggestions on what it could be??? or where could i take it??? This noise is really becoming a joke and embarrases the hell out of me when i am going for a crusie and all u can hear is squeeking. :wassup:
so all criticism and suggestions are welcome. :cheers:
https://www.sau.com.au/forums/topic/62508-advice-needed/
as the rubbers cool they shrink so as to then move a round slightly within the sockets, as they heat up they expand so the squeaking stops, that is the best answer i can give you. I would take it to howard revell if you have not allready.l
https://www.sau.com.au/forums/topic/62508-advice-needed/#findComment-1177689
Well.... no actually. 'Stock' suspension bushes (eg. lower control arms) are rubber bonded to an inner and outer sleeve, with the outer press fit in to the suspension member, and the inner clamped by a through bolt. They don't shrink/expand, and they don't move around.
https://www.sau.com.au/forums/topic/62508-advice-needed/#findComment-1177702
thats what on of the guys said also. but only one has said that.
That doesn't really answer the question...
Assuming you do have poly bushes in the suspension, then squeaking is normal, and you should disassemble and re-grease the bushes. Use a molybdenum grease or assembly lube - don't get it on your skin, however...
https://www.sau.com.au/forums/topic/62508-advice-needed/#findComment-1177981
Ed lubed them all up but it still does it. what changing all the bushes help. why does it only do it in cold weather
Well - you don't lube the rubber bushes, so I guess you must have polyurethane. Was it lubed with moly? Regular greases don't to the trick.
Polyurethane is a plastic, so it is affected by temperature to some degree. All of the poly bushes squeak, even the graphite impregnated ones. Some people add a grease nipple so the bushes can be greased in place (not sure how effective this is, as the grease needs to get down to the centre support tube and the ends).
https://www.sau.com.au/forums/topic/62508-advice-needed/#findComment-1178111
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
