Well sum 1 did a hit and run on my today.. :)
my driver side front fender is sorta crunched in and i got dunt just above the wheel and sum scratches on my front bumper..
this is so gay...
it's gonna cost me a bit to fix it up..
sigh...
anywayz...hope this happens to no 1
https://www.sau.com.au/forums/topic/62719-hit-and-run/
crap. i park there all the time, have the datto now, but in 1 week I'll have the GTR
I try to park away from every other car in the place, the bastard was probably parking, hit you, then thought I better move to another section of the centre so he doesn't catch me. probably an old person in a volvo mate
hope it doesn't cost too much to fix up
mark
https://www.sau.com.au/forums/topic/62719-hit-and-run/#findComment-1184972
Same thing happened to me the night before the Newcastle Cruz a coupla weeks back but it was minor, I parked my '33 out the front of my mates place while we were inside having a session, then suddenly we all heard a light noise like two cars had made contact, I didn't bother going outside at the time to look cause we were all pretty bent and we weren't actually sure if anything did happened. I found the scuff mark on my front bumper a few days later. I know who it was because of the color of the mark left on my car but the stupid bitch didnt even have the decency to come to the door to let us know. If it was me who done that, I would've at least left a note on their window or something. Ever since then, the girl pretends that she didnt see us everytime we cross path...... guilty conscience maybe.......
https://www.sau.com.au/forums/topic/62719-hit-and-run/#findComment-1185764
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
