Hi all,
Time has come to fit an aftermarket oil pump on my earlier RB26 block, I've done a search and was not able to come up with a solid answer...
The Nissan N1 oil pump will not fit straight up I have read?
What modifications/parts are needed to fit this onto an otherwise standard crank/drive?
Kindly appreciate any help, thanks
Just found this from thread titled GTR Crank Questions...
R33 and R34 cranks have the longer collar to run the oil pump as the R32 cranks had a thin one that can cause the pump to fail. You can add the collar to them.
I don't think there is any strength differences, if there are it's minor.
isnt the only differance between the n1 pump and a standard pump is the pressure spring? the n1 pump has a harder spring in it to give it higher pressure?
steve
Correct, just put an 8 psi stronger spring into a standard RB26 oil pump. Bingo it's an N1:cheers:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
