Im sure you will find one if you shop around. It always pays to search and not to rush into a purchase. Wether it be a single part or a whole car.
Hell, post a "wanted to buy" add in the classies on this website, worked a treat when i was looking for bits n pieces for my car. There are alot of ppl with access to parts etc on these forums.
Thanks geordie, how much extra is a manual half cut?
I read that whole RB30 thread ages ago, and I know about the oil galleries. But I recal something comming up about the VVT not being better... something about the the VVT only making up for lost power from smaller cams nissan used for emmisions....   Can anyone clarify this?  Sounds like VVT head with non VVT cams would be the go.
Don, I just looked at you pics.  That is one sweet sleeper.   What is the economy like on the beast?    Do you think an LSD and some cams would bring you a 13?
yep the red wagons a sleeper , totally stock looking , standard hieght and wheels . at moment have put roll cage in for going to speed trials in 3 weeks . fuel economy is ok , almost run out of fuel the other day it took 55 ltrs for 490kms travelled .
maybe 4.11 gears with a locked diff , cams and the head ported should see high 13s for the 1/4 . i have got a spare head to play with , will get it done one day .
Sounds about the same econ as a standard RB30E. I don't think you would need to port head for a 13.9, I'm sure the standard cams are tiny and some big ones would make a huge power gain. They would probably cost a mint though. Are you from/or visit redcliffe sometimes? I have seen a wagon that looks very similar to yours around there a few times.
cams cost around $900 -$1000 . no not from redcliffe have been there a few times . i use the wagon as my work vehicle so i get all over brisbane . am taking it to lake gairdner speed trials in south australia in just over 2 weeks
Its a load of crap buddy.
The RB25DET VCT cam specs are the same as the R33 RB25DE and RB20DET but with different center lines.
The VCT adjusts the inlets centerline so there is less overlap in the low/mid range but larger overlap in the top end.
If you were to have the larger overlap at idle the car motor would idle like crap almost as if it were running a large cam.
I have an RB30DE in my R33 S1 now for 18 months. Theres a picture on this thread (page 1) by Skyla dated 30/01/05 of my conversion. I Have a RB25 S1 head, with RB20DET inlet cam. This is so adjustable cam wheel can be fitted when I have time. The throttle body is a self made 80mm leading to a trust filter behind the bumper above the splash panel. RB20DET injectors fitted (top mount) are feed by an adjustable fuel pressure regulator set to 37 psi. Exhaust is via coby extractors to 3" exhaust with 2 mufflers.
So far only problem was using a bolt for the second idle pulley. This broke as I was pulling into my car park at work causing cam belt to slip over cam wheels. There was no damage by piston / valve contact. It now has a stud fitted similar to the original one.
My complete conversion so far is about $3000 with manifold being the greatest expense. I have 137 rwkw at the moment and the car is my daily driver.
For all you N/A fans, You don't need a turbo to have fun. My personal number plate is SLOG (slight lack of grip).
HAVE FUN
Suiram nice work on the engine mate. Can i ask what plenum you have on it? At first i thought it was a GTR plenum but now it could be a Greddy one. Also were the extractors custom made by Cobe? Cause they sure look better then the coby ones ive seen. Nice work again. Hows the response and power delivery?
Thanks, Inlet is a trust plenum and extractors are HPC high temperature coated coby. The car pulls like a tractor, 1000rpm to 7500rpm. Dyno sheet has 2 straight lines, torque horizontal and power upwards till cutout. Its nice to drive and fuel economy is good too.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
