I have an R33 Skyline GTS-T Turbo automatic.
Anyone had a problem with the tacho (RPM) part of the cluster not working properly?
Mine seems to gradually run clockwires from 0 all the way round past 9000rpm over the space of about an hour. I have tried to obtain a second dash cluster but I cannot seem to find one cheap. It has worked once or twice at times, but very rarely.
Is this an issue with the tacho, or the connection?
Anyone know where to get a dash cluster fairly cheap?
Thanks.
BOOMAU
https://www.sau.com.au/forums/topic/63005-my-tacho-is-screwed/
Pull out the instrument cluster. you have to take out the plastic dash shroud that covers the steering wheel, and the one around the aircond/deck. There are 3 plugs so dont worry about not being able to put it back together again. Unplug and reconnect. You may want to check the connection running into the ECU in the passenger side kickpanel...this is held in by a bolt so doubtful that its that.
May be the actual tacho itself, surely you can just buy a replacement tachometer and slot that into the intrument panel instead of buying the whole lot. you could probably give it a crack yourself and if you run into any problems go see an autoelec.
Pulled out the whole dash, checked all the connectors to make sure that they were all securely conntected and replaced it all.
Still not working....
Anyway, because there is power going to the tacho I really dont know what is going on, the tacho is still moving slowly from 0rpm to over 9000rpm over the space of 1/2 hour.
Obviously the tacho is working on some level, idle and running of the car is fine, I just got no idea what rpm I am doin and it is really starting to bug me.
Thanks for the help, guess only other solution is to try another tacho, cluster and see if that works.
BOOMAU
mine does what yours does too, and fcuk, it is the most annoying ever!!! Its almost comming to the point not im just going to leave it faulty, and run an aftermarket 3 3/4" tacho.. seems like a better idea to me.. plus might be cheaper!!!
let me know if a new cluster fixes it though..
I had (still have) problems with the speedo which is a common prob due to wind backs.
Goes straight to 60km/h weather your doing 10km/h or 120km/h
I wasn't going to spend money fixing it when you can get an APEXi RSM instead.
Exactly what i did and i love it :D
Good for those 0-100 times too. and removes the speed cut.
..and looks sexy!
Probably get one 2nd hand for $250 maybe?
But yeah, has revs too and mine is just velcro'd inside the dash
Plus everyone knows having a quick glance at a tacho or speedo neddle is easier to recognise to the brain than a digital readout. Plus a tacho with its needle design looks heaps better when you rev it up.... Its like almost there, almost..... yeah redline....
True, but when they check it if i get pulled over it goes to zero whcih is correct.
Hehe :D
Plus i can get rid of it if cops are around.
Rip it off and hide it under something (unless they search the cabin off course)
Also, you can set it up so the ecreen will flash at any rev level you want.
One bad thing i don't like about it, which doesn't happen very often, is the sun glare off the glass/plastic face. Normal speedos don't seem to reflect at all so you can always see the speed. Not so with the RSM, but definatley livable.
Definatley a cover up option like you said, but so good at it, i aint fixing the speedo.
it happens to mine, but what i did was i pulled out the whole dash bit and if you pull back the front back of the tacho with all the numbers on it tap the unit behind there or check the wires.. i hit mine and had it connected still with the car running and it starting working again.
Wow, might just try that, I had the tacho out yesterday and once I got it out and checked the connectors to see if they were securely in, I just put the stupid thing back.
I might try it again and see if I can pull off the glass front cover and peel back the tacho cover bit and give it a few taps (possibly punches depending on how frustrated I get with it hehe) check the wires and see if that does anything.
Are there any problems just hooking the tacho up with everything else unplugged (ie aircon, hazard, dash light dimmer, etc)?
I wouldn't think so, but possibly thought that if something wasn't plugged in, car would sense that and somehow screw up the computer.
Anyway, thanks all for the ongoing help with this one, if I figure it out, I might post a thread on what I did in detail for others to try.
Hitting the dyno today, with my stock standard R33, hopefully everything is A OK under the hood so I can start tweakin my little baby up.
Cheers all
BOOMAU
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
