Hey guys just heard back today that the reason i have lost boost is because my front turbo has seized up. I bought the car thru prestige. Now i got the choice to rebuild both thru Keir Wilson with steel wheels for the price of around 3000 or i can put in a 2nd hand front turbo. Ive been told the 2nd hand stock one will cost around 600 but theres no guarantee on the condition. Any tips? If anyone knows any reliable places to get 2nd hand turbo's with sum sort of idea on the condition can you please let me know.
Regards,
Deren
https://www.sau.com.au/forums/topic/63168-r32-gtr-front-turbo-seizure/
for that price you could get yourself some r34 n1 turbos. have a look around at different aftermarket turbos. if you dont have the money, just get some 2nd hand standards and get them checked out.
give Tony a call at just jap he was the cheapest to rebuild standard turbos, i must have rang about 20 diffarent places. when he quoted me he fully rebuilt the standard items with ball bearing core's and steel exhaust wheels each turbo rated at 290-300hp. all of that for $3000.
I would if i had the cash but for now ive just stayed witht he stock turbo's till i later upgrade to something more special. Just dont have the cash..
Actually turned out that the front turbo exhaust wheel snapped off as always, but seeing i was driving it still for awhile it pretty much turned into dust..Still contrary to another post i was ready where two guys were argueing about the dust going back thru the engine this didnt happen on mine. Apparently i either would have had a big backfire to cause it or over boosting. The car has no mods at all, apart from a little thing wired into the ecu. Looks kinda like a loom connector but has no connection for anything to be plugged into it. Could it be a boost limit cut or something? I first thought it mite have been a speed limit cut but i dont think i ever got the chance to get over 180 before this happened.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
