broadwater carpark
Guest Boxhead
Do any of you guys reguarly go to broadwater carpark?
if so.. would it be cheesy if us skyline guys parked close and shit like that?
sorta like what the commonwhores did the otehr week.. it looked good to have a commonwhore section.. that way we could skip going near all of them at once.! hahaha
https://www.sau.com.au/forums/topic/632-broadwater-carpark/
yeah i reckon that's a good idea.
this weekend will be my first time at the broadwater with my new car so it would be good to have other skylines to park next to.
we should post what our cars look like and our names so we aren't just standing there wondering who everybody is and if there from skylinesaustralia.
i'll start...my car is an r33, it's wine red with 18" wheels. it's got an "apex power sport" sticker on the front bar, and my name is shane.
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14798
Guest Boxhead
yes... brilliant.. some one is some ppl are suporting me... my car is a gun metal grey r32, its p[retty stock, has a nismo sticker on the back window.. quite large.. my rego is XXX-662
my name is michael... yeah.. i dunno if i can come or not.. coz it comes down to who can come with me ( im on my l's) so i need a bloody driver.. but anyway.. ill sort some shit out.. if you want.. gimme a call when yoru heading out
0413115376
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14806
Guest Boxhead
yeah i know the place is crawling with the cops, but you see, thats why i mentioned i need a driver.. ive driven like.. 3 times up.. you just gotta know not to do anything stupid, as in.. drag off lights, or be a general idiot in a motor vehicle.. then you pretty fine...
when i said rego.. i meant number plate
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14822
Well I wouldn't be driving around there with your L's, bloody coppers pull you over for looking at em wrong
it's only a $30 fine and I got this info from a copper, the only down side is they will make you get out of the car to get some one else to drive it home.
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14945
Birty... you are such a knob... Dont know what your rego is :mad: hahaha
anyway..
I'm Erin, I drive an R33 GTS-t and will most likely be down the coast on sat night...
Our Numberplate is 51NNR..
We are usually with a vl commodore or a white R33 with the number plate 15 FAS...
We also have a UHF "dickie smith special"
Comes in handy when cruising and stuff...
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-16187
Originally posted by Birty
Well we're having the mad mountain cruise this weekend, not sure if it's gunna be saturday or sunday yet, but if it's saturday then i might go to the BWCP afterwards.
Birty
whos going on this Mountain Run
I haven't really heard anyone talk about it lately!
Except slip saying he didn't wanna drive his car.
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-16188
I'm sure you'll meet them at the end
We aren't going cause funds are a little low atm.
Guy who we sold the kingswood too told us he would have the money for us last week... and we got our alarm on the weekend and the guy still hasnt' given us the money...
But the alarms pretty cool...
I still go to lock the car when its already locked.. or unlock it when its alreayd unlocked.. The blonde in me!
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-16214
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
