broadwater carpark
Guest Boxhead
Do any of you guys reguarly go to broadwater carpark?
if so.. would it be cheesy if us skyline guys parked close and shit like that?
sorta like what the commonwhores did the otehr week.. it looked good to have a commonwhore section.. that way we could skip going near all of them at once.! hahaha
https://www.sau.com.au/forums/topic/632-broadwater-carpark/
yeah i reckon that's a good idea.
this weekend will be my first time at the broadwater with my new car so it would be good to have other skylines to park next to.
we should post what our cars look like and our names so we aren't just standing there wondering who everybody is and if there from skylinesaustralia.
i'll start...my car is an r33, it's wine red with 18" wheels. it's got an "apex power sport" sticker on the front bar, and my name is shane.
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14798
Guest Boxhead
yes... brilliant.. some one is some ppl are suporting me... my car is a gun metal grey r32, its p[retty stock, has a nismo sticker on the back window.. quite large.. my rego is XXX-662
my name is michael... yeah.. i dunno if i can come or not.. coz it comes down to who can come with me ( im on my l's) so i need a bloody driver.. but anyway.. ill sort some shit out.. if you want.. gimme a call when yoru heading out
0413115376
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14806
Guest Boxhead
yeah i know the place is crawling with the cops, but you see, thats why i mentioned i need a driver.. ive driven like.. 3 times up.. you just gotta know not to do anything stupid, as in.. drag off lights, or be a general idiot in a motor vehicle.. then you pretty fine...
when i said rego.. i meant number plate
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14822
Well I wouldn't be driving around there with your L's, bloody coppers pull you over for looking at em wrong
it's only a $30 fine and I got this info from a copper, the only down side is they will make you get out of the car to get some one else to drive it home.
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-14945
Birty... you are such a knob... Dont know what your rego is :mad: hahaha
anyway..
I'm Erin, I drive an R33 GTS-t and will most likely be down the coast on sat night...
Our Numberplate is 51NNR..
We are usually with a vl commodore or a white R33 with the number plate 15 FAS...
We also have a UHF "dickie smith special"
Comes in handy when cruising and stuff...
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-16187
Originally posted by Birty
Well we're having the mad mountain cruise this weekend, not sure if it's gunna be saturday or sunday yet, but if it's saturday then i might go to the BWCP afterwards.
Birty
whos going on this Mountain Run
I haven't really heard anyone talk about it lately!
Except slip saying he didn't wanna drive his car.
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-16188
I'm sure you'll meet them at the end
We aren't going cause funds are a little low atm.
Guy who we sold the kingswood too told us he would have the money for us last week... and we got our alarm on the weekend and the guy still hasnt' given us the money...
But the alarms pretty cool...
I still go to lock the car when its already locked.. or unlock it when its alreayd unlocked.. The blonde in me!
https://www.sau.com.au/forums/topic/632-broadwater-carpark/#findComment-16214
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
