based on who ordered first. the huge problem is on R33 bonnets becos all of them get damaged! i am really pissed about it... i do have one other R33 bonnet but of different style... so i will put up for those who already ordered them in pecking order...
but also i will prefer to send to those based in sydney becos although the bonnets are okay, some of the boxes wont stand another delivery interstate.
mate... the boxes conditions are so bad... 3 pallets.. 2 pallets are okay... 1 pallet completely damaged.. and all the skyline bonnets :(
sigh*
  • Replies 90
hmmm...can you get more bonnets? How long?
i am still contemplating if i should do this anymore. honestly, the margin is low. cost of CF is increasing coincide with increasing cost of petrol it seems.
i am happy to bring it, but at the moment, if i cant get any sort of compensation for the damaged bonnet, my hard work any money that i earn is completely wiped out.
so i will see how it goes.
sorry for the lack of communication.
those who ordered with me for R32 series 1, the bonnet is okay except for 1 bonnet.
all those who ordered R33 series 1, will need to have the money refunded as all the bonnets are damaged. howver i will throw in m4 free bulbs as a token of my apology
thanks :D
Cool, i shodl be ok then...well im in melbourne at the moment, but will be in Sydney next week, be great if i can get the now bonnet on before the day at Eastern Creek on Friday:)
Roy just get 1 of the damaged one man, it will go perfect with the rest of the car :(;)
Chiba boy sorry to hear you got damaged bonnet.
They looked awesome on the photos hope the quality was good for those who got them.
I realise this is probably the last thing on your mind but wondering if you're contemplating doing a31 cefiro?
Long shot :)
Hey All, sorry to about the problems Leo.. guys i bought the First 32 one he got in back last december.. im selling my car now.. so if anyone wants a 32 bonnet this style let us know.. im in newcastle.. $850...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
