  • Replies 184
hey adrian unfortunatly i wont be racing, my jap spec roll cage didint even come close to passing the engineers requirements, everything changes after 10s, need full race suit, kevlar cover for bell housing or what they call shatter sheild, 5 point harness, so im out for another month or so
What happened to http://www.skylinesaustralia.com/forums/sh...4058#post954058 hahaha you were told it wouldn't pass months ago :D
im buying a straight bolt in one, anyways if they dont accept it, ill just change the plates over and drag like my first time
I don't think Jap cages are built to one particular standard anyway.
As for tech inspection, I am sure that I was told by another drag racer that a half cage is passable, but can't recall under what circumstances. Anyone?
Half cages are not acceptable. The rules are clearly laid out in the ANDRA rulebook. you need a minimum six point welded cage.
I spoke to some people in the know last night and was told that for a car that runs 10.00-10.99 a half cage is fine. Any quicker and a 6 point cage is required. I was also told that (techncally) it didn't have to be welded in, but that ANDRA won't pass it if it isn't.
Yes, you're right. As long as the trap speed stays under 140 MPH and the ET is slower than 9.999 you can fit a half cage with an intrusion bar. I don't think you'd bother though because it's easier to get the full cage done and be done with any more hassles no matter what ET or trap speed you run (as far as roll cages go).
4.4.7 Roll bar/cages
Street registered cars with a fixed steel roof and unmodified monocoque construction running between 10.00 and 10.99 (1/4 mile) and/or less than 140 mile per hour (225 kph).
Single rollover hoop covering the full width ofthe drivers compartment with two bolted backstays and a bolted side intrusion bar constructed to ANDRA requirements as a minimum.
All other sedans, sedan based or open vehicles 10.99 and quicker.
Full roll cage mounted at a minimum of 6 points.
Hey all the classes are DYO - where is the fun in that? Was about to fax the entry form until I saw that.
So not only do they have a specific DYO class based on E.T., but now all of last years heads up classes are reduced to a pathetic, boring, grandma class. The only heads up category is the Pro RWD? Street racing is not drag racing, but someone hitting the brakes before passing the timers is not drag racing either.
Ahh found the small print
PRO RWD will race heads up with quickest 8 vehicles competing under the 3 Round Formate System. Sport FWD, Sport RWD/AWD, All Motor, Front Runner, Sport Mod & Oz Mod will race on a Dial Your Own Handicap system with the quickest 16 vehicles competing in Elimination Style racing. Non-qualifiers with these classes will automatically drop into the ET3 Bracket for non-qualifies and continue racing elimination style.
Quickest 16 across all the classes? Or per class?
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
