  • Replies 44
Being a former "rexy" owner, my advise is don't drive the GTR like the WRX.
Yes, the GTR does drive like a RWD. It only engages 4WD mode when the rear kicks out. Don't try to counter steer too much when the rear kicks out. Use about half as much and keep your foot on the throttle.
Like any 4WD, brake before you enter the corner to balance it out. Failure to do so and it's understeer all the way.
You may think the WRX is faster out of corners, but in reality the GTR steps all over the WRX.
Guest Nismo_Freak
Also note that the WRX is lighter and has less torque than the GTR which makes the AWD system "lighter" feeling meaning it does have a gross over/understeer. The Subaru system is a 50/50 distributed AWD where as the Nissan system is a 40/60 (rear gets the larger bit) to make the car react more like a RWD car. From watching videos I have noticed that the AWD system kicks rather sharply when it gains traction. Usually AWD systems like to push out when they are under load in corners but the GTR should remain fairly balanced with its spring rates, suspension, wieght distribution, etc. Just go into the corners and react is all I can say... its when you predict what the car is gonna do when you get in trouble. Just whatever you do dont lift throttle when you are cornering hard... it can make you spin out.
The WRX is idiot proof. Well, almost. It's more forgiving. I don't know how ram-raiders roll and lose control of WRX's.
Go to the race track on a wet day and you'll learn very quickly. In the wet, you don't need too much speed to get it sideways and see how the 4WD works. Just don't speed too much on the straight.
minh.. best way is to just take it to a track and see how it reacts when pushing it.. tis much better to find out on the track than on the road :cool: though it is kinda fun on the road though..
actually theres a track day today :) .. should have gone given it some :) actually bugger it... jump in the passenger seat.. adn ill take u for a drive.. just gimme a couple mins to sort out what to do with 4wd
i always find slow in fast out works with my gtr keeping the pedal down seems to straighten them up well , you can always fit a 4wd controller wind on a bit more drive on the front similiar to the n1 and they loose that taily bit.
Stevehttp://www.justjap.com
Hey steve thanks for the reply?
How much is this thing your speak of?
Having previously been a WRX owner also the Wrx has shocking understeer which limits your turn in speed drastically but as the 4wd system is constantly in operation it comes out easier (not faster but it is easier to get it right.)
The problem with the GTR's is that the Latitudinal Sensor sharply reduces drive to the front wheels whilst cornering thus bringing on vast amounts of oversteer if the driver wishes or allows. This will greatly effect your cornering speed especially your exit speed. As mentioned above the best way to fix this (and for me it should be fixed by anyone who cares about their cornering potential) is to fit a torgue spliter (or in real terms an amplifier) so that you can control the level of control that the latitudinal sensor has on the car. This will allow the bias to the front wheels to increase durin and exiting corners and will greatly improve the cornering and predictability of your cars cornering. This makes the car incredably neutral and will allow vastly higher cornering speeds and much earlier exiting apex's.
I built my own torgue spliter and am currently looking to re config the board etc for it but will be happy to build some if enough people are interested.
Mick.
Are you guys talking about torque splitters like the HKS Torque split controller?
with things like this if you give the front more then is this a constant thing meaning that when you drive in a straight line you will have more drive to the front still? or is it adaptive or progammable?
400hp,
I do not know what the HKS splitter does but the one that I built does not drive the front constant it simply reduces the effect that the latitudinal sensor has on the attessa.
The GTR's have three sensors (2x Longnatudinal (to measure + & - g-forces) and 1 X Latitudinal (to measure sideways g-forces). Once the longnatudinal sensors measure a certain amount of g-forces it will engage the front wheels as it has assessed that the car can be wheel spinning. However once you turn a corner hard (you must be under acceleration for the longnatudinal sensor to bring the front wheels in) the latitudinal sensor REDUCES power to the front wheels, thus making the car very "taily" in it's handling. What my splitter does is allow you to dial in how much influence you want the latatudinal sensor to have and thus dictate how much front wheel drive you want durin cornering whilst accelerating.
It must be remembered that the longnatudinal sensors are the once that brig the front wheels into the equation so unless you are accelerating you still will not have any 4wd exactly the same as it does standard. The spliter simply reduces the power of reduction that the latitudinal sensor has. In a straight line the car will perform as standard. In corners however you can dial in how much front wheels you want.
You could achieve that possably by changing the sensor (lat) but with the dial so that it can be varied you can alter it as you desire for such variances such as wet or dry, slow or fast corners. It makes the car vastly safer and greatly alters tha handling characteristcs of the car making it incredably neutral.
One of the things that I have always found a little disapointing about the GTR's is their handling (I will say the same for the WRX except it is far harder to fix) due to the oversteer problems that they suffer. The splitter cures these problems and makes the GTR one very imrssive handling car, for a road going car.
For the record I also encourage people to get rid of their hi-cas if they wish to improve handling.
Hey a good set of Koni's will also help.
Mick.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
