i have heard so many mixed reviews on these pumps...
i really dont know what to go for.
like a bosch 040 or something or one of these?
I have read there are 4 types of walbro pumps in terms of fuel pressure..
Wwhich ones are these?
Are these a true direct replacement? if not, what needs to be changed in order to install one of these (R32 GTSt)
defaintely much cheaper than the bosch pumps...
ill do a little research and i might take one.
If you could answer the questions the best you can hat would be great.
Cheers
Cheers
Hi,
These are the best ones > GSS 341 >
Believe it or not, i was flowing 400rwhp on my car with 26psi of boost.. 40psi is base pressure + 26psi of boost = 66PSI of fuel pressure @ 400rwhp!
Running standard voltage of 13.5V! These puppies flow more then a bocsh 044 @ 16V and its totaly SAFE!
Ching ching! :(
yeah, the are much smaller than a bosch unit.
Easy enough to fit... the rubber sleeve thing it a pain though.
Pity they dont work as well as they are "meant" too.
throwing my walbro out in place of a bosch.
What is the part number of these...
And I thought the standard R33 ump flowed 190lph??? or is that the GTR???
Hi
There is allot more in a pump then "it flows 190lph"
What Fuel pressure? what voltages was it tested at etc?
Part number is GSS341
They will fit in R32.
The rubber thing on the bottom, will suit R32.. Nismoid did you buy one off a silvia seller?
The standard R33 pump according to my roughly translated Japanese specs is 190lph, 12-14v (unsure I cannot translate part of it) and at 41PSI. Oh and I know there is more to a pump...I asked a question that is all...
Oh an that cannot be the whole part number...pfft forget it
Guest
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
