Time to sell the Skyline
It’s a white R33 GTS25t manual 4 door type M
It was imported two years ago with 70,000km and was auction grade 4 it now has 98,000 km, I have serviced it every 5,000km using Motal oil.
It is essentially stock but has Whiteline suspension bits in it and I have just spent $600 getting the windows tinted.
It also has a tow bar rated to 850kg that I had fitted to tow my motorbike (only 300kg).
Apart from a few minor stone chips on the front bar this car is immaculate; I have even had some people think it was a new car. I don’t think the back seats have even been used. It has been kept under cover day and night and barely even driven in the rain.
I love this car and don’t want to sell it but I need something I can use to tow my rally car. I have just paid the rego and have a valid RWC for it.
$16,500 ONO
I am in the outer north east of Melbourne and the car can also be viewed at work in Campbellfield.
Mob: 0439 304 903
Chris
  • 3 weeks later...
You dont have to be in Melboune.  It's repalacment came from Perth
sory mate, i couldn buy a car without test driving it or at least lookng at it. ;) and i don have the time to travel to melb...
will you be able to tell me what options does the car has
any modifications
does it come with RWC
any rego!
tell me your last price
to tell you the truth i can get one imported from japan for $16000
and the importer will even modify some stuffs after compliance
cheers
Kev
It has a Whiteline works suspension kit that consists of up graded sway bars, caster and camber adjustment kits, Bilsteins shock, lowered Whiteline springs and a front strut brace.
I have also fitted a HKS Turbo timer.
It comes with RWC and 11 months rego.
You may well be able to get one imported for $16,000 but you don’t get to see what you’re buying, you have no idea if the mileage is correct. You will also find that if you order now you could well be waiting many months for the car to be shipped due to the massive rush that is on to buy and ship 15year old cars as a result of the impending rule changes. i doubt that price included on road costs so you can add another $1000 or so there.
I have reduced my price to $18,000 I am checking to see if any of the suspension bits can be transferred onto my new car if so I will drop there value off the price.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
Someone come any buy it this weekend I cant fit the new car in the garage now.
where did you get the tow bar from as i have been told you cant get them for 4 doors....pm me with details please (desperate) wheres it bolted to???
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
