I have a Power FC on the way for a R3325t with a cat-back exhaust as the only modification.
I was going to plug it in, see how it goes and then spend the money getting a tune when I get a front mount & boost controller later on.
Anyone thinks this is a reasonable idea. I believe that the base tune is actually quite good for the R33 as it is.
Anyone done it this way before?
Thanks
https://www.sau.com.au/forums/topic/63836-power-fc-with-no-tuning/
Guest two.06l
Thanks
Great idea, we made 284rwkw out of a GTR with a base map and some injector correction values reduced to lean it out a bit.
Im using a modified base map and constantly watch the knock reading. The max im getting is in the mid 30's so im happy with that, once ive seen 40. Im very happy with the extra performance and particularly no flat spots. If you monitor knock you should be right. If your getting knock, try reducing the timing down 1 degree. Bit of trial and error at the moment so keep your eye on the knock readings.
what are acceptable knock readings?
I have a R32 GTSt, and i also have a power FC with commander but its not in the car yet as i was waiting till i get something in the car where i actually need to get it tuned. as i didnt want to tune it now then tune it again later when i mod the car. as i cant really afford it.
I put it in just for a squiz once and it was reading things up on the knock sensor. but i didnt know what the knock sensor should read and whats bad etc, so i took it back out
Anyone?
Thanks for the input
dont play with fire.
why cant you wait and plug the PFC in when you get a cooler and get it all done properly?
Thats the thing, I could wait but if I can get the benefit of the Power FC without tuning it yet then why not.
PFC base maps are set up to run on stock engines so thats why I'm thinking about doing it that way.
Thanks two.06l & Robo's sounds like it worked well for you guy's.
Anyone used it on a stock 33 25T though?
Keep in mind the PFC doesn't retard timing if knock is detected.
That said, My setup has not seen any dyno time yet but I have it setup to run 11:1-10.5:1 a/f under boost and my knock usally stays under 25. Last week it some how shot to 70. I never saw the check engine light but I wasn't looking either.
How you measuring A/F ratios without a dyno?
i can see what you mean. But if something does go wrong then your up for a motor rebuild quite quickly... when it was very avoidable to begin with
guess i like to do things as safe as possible
My 20 cents worth;
Plenty of cars are tuned without dynos
Ignition timing is easy, advance it till it pings, then knock it back 2 degrees
If you have a PFC you can read knock off the Commander, keep it below 40.
(the dash warning is adjustable via the Commander)
Fuel mixtures are pretty easy to read off the spark plugs, it's been done that way for many decades
If you want to be more precise, you can buy a pretty good A/F meter with a fast and wide lambda sensor for under $500. Spread that amongst 3 or 4 guys and you have cheap tuning for ever.
Most tuning time is used up setting the base parameters (though not much of that with a PFC). When you make further upgrades the required tuning changes are not very dramatic. This is the big advantage of the Power FC, it uses the AFM sensor as its main input. Most upgrades that you do result in changes (hopefully increases) in airflow, that the AFM sees. An example, I have changed intercoolers 3 times and the tune barely changed at all. Maybe 15 minutes of fine tuning on the dyno.
It is always better to develope a rapour with your tuner, so frequent small visits will get you a faster, nicer running, better tuned car than one only visit.
Everyday you drive around with a rich running Skyline costs you $'s in fuel. Not to mention less lambda sensor wear and freer flowing cat.
Bottom line, get it tuned now:cheers:
SK,
Do you play with the timing curve in the low to mid range?
How do you know where it pings there with minimum load?
I have quite free access to dynos so i can play with the mixtures at different load points. Its the timing im a little new at. I know more means better until a point. (We once turned the dissy on a holden v8 from 10-14 degrees and gained 13rwkw) . Generally if you hear ping, retard it.
My PFC is untuned and right out of the box. My A/F gets really rich on the topend. 9.8 was peak hold on my wideband display. running really rich but it runs smoother than the stock ecu.
Before it warms up the sensor
Still warming up but it displays everything you see. I haven't hooked up the EGT gauge or the mapsensor yet. You need a laptop to datalog the values you see + TPS and RPM.
SK,
Hell yes, that's where you feel the biggest improvement in response, not so much power. You can get quite a bit of earlier boost build by advancing the timing.
With the above in mind, I keep advancing till it pings or the boost starts to drop off. Whichever comes first. On the dyno, you simply watch for power drop off, but that usually corresponds with a boost drop or some pre-ignition anyway.
You can also see it on the AFM voltage, if you go too far (advanced) the airflow drops off.
You got it.
:mad:
Thanks for the help everyone SK, BlueRB240
At this stage I will hook it up and see how it goes.
If knock rating getting over 40 then I'll get a tune for sure.
They are such a reasonable price these days it looks like it will become more common to get one early on in the modification process.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
