Chilli EAT OFF! - Tues Feb 15th 2005
Are you unable to read? I thought I had made it quite clear, or do i need to do another "Follow my Pink Bits" mspaint masterpiece? ;)
Ska the smart ass.
So its in a building at the Hyperdome, like within the car park, or inside the Hyperdome it's self.
And yes pink bits map would be nice.
  • Replies 139
Ska the smart ass.
I like pink bits
Alrighty then follow my pink bits ;)
Mum would be so proud of that effort, didnt even have to use the text function, did the writing MOUSE style, could you notice? :(
The booking shall be made for "The Honourable Councilors for the Borrough of Harrow"
Haha you better, cause I don't want to look like a tool asking for that table when you really booked it under SAU or something ;)
Need 8 or more people to make the booking but will definatly make it for "The Honourable Councilors for the Borrough of Harrow" as it should be now duely noted in the minutes.
Could you point to the exact part of Cyrus' pink bits on which the M2 resides? I've already thouroughly inspected them myself, but have been so far unable to locate it, or anything else of significance in the general vicinity.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
