Motor:
R32 Silvertop RB20DET
5sp Supra gearbox w/ single piece tailshaft
Turbonetics T3/T4 turbo
600x300x80mm FMIC
Oil Catch can
K/n Pod filter
3in Mandrel exhaust and dump
Exterior:
17" wheels front 215's, rear 235's
XR6t mk2 Rapid Yellow respray, with light white pearl and glitter/sparkle gloss.
GTSR HR31 front spoiler lip
Late HR31 front end update with projector lights and passage grille (used to have box front)
Kept standard import HR31 rear taillights and garnish. Rear bumper update to Late HR31.
Suspension:
S13 coilover suspension all around
Whiteline strut tower brace
Brakes:
Fronts, R33 GTE rotors (4stud) 280mm with larger vents than standard r31.. twin piston calipers
Rear, standard - bendix pads
Interior:
Retrimmed doorcards to yellow
Seatcovers in yellow, just to brighten it a bit.
Black dash and interior conversion from late HR31 (originally blue).
I am in need of space so this vehicle must be sold.
Please contact me on 0402 807 417.........vehicle located on the Gold Coast Qld
OOPs.......I forgot to add that :(
I have previously advvertised it at $8900 but due to space constraints i am considering all reasonable offers..............It is amazing what CASH in an envelope will make me do :D
  • 4 weeks later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
