  • Replies 52
Does look too bad at all.
You said it wasn't a perfect fit... Where does it fit not so right ? Any chance of a few close up pics ??
Then the decision.. Leave the gauge holder black and get a silver gauge, paint the gauge holder grey to match the A pillar and get a silver gauge, or leave the gauge holder black and get a black gauge...
Who's good with PhotoShop ?? :(:D
J
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1203610
I have a boost gauge mounted on the A-pillar. It's in a pod I bought from Modyourcar.com for the R33. It's not a perfect fit but it looks O.K.
That web site is painful to use, I searched up and down, left and right, I can't find a single gauge pod for an R33 GTST. I can find a univeral one for ~$20, is that it?
Hi J , I vote for black POD and black gauge.:(
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1203679
I've been quoted from etperformance (www.etperformance.com.au) that they're $37 for black or $49 for carbon fibre (look).
details
E.T. Performance Products Pty. Ltd.
6 Short Street
Dandenong
Vic. 3175
Australia
Ph. (61)-3-9794 9044
Fx. (61)-3-9706 8171
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1203714
I have three defi guages in my centre console wheer the two centre vents were. I removed the vents and stuck the three 60mm guages there. I blocked off the vent behind withthe exception of four outlet holes which I routed via plastic pipe to blow air out between the guages into the main cabin of the car. I did this to help airflow when the air conditioning is in use. If any of the vents are closed or blocked air will be forced out the remaining open vents at a higher rate, so the side vents are doing an okay job for front passenger and myself. Also means the install is fairly clean, not advertising to general walker-bys that it's loaded with guages as well. I also have an Apexi RSM that is mounted just in front of my rear view mirror (G-sensor in the roof lining in the cavity around the roof/light controls), It sits up there, behind the sun strip quite nicely and again out of site to passer bys. Still very viewable from a driver perspective (you look at your rear view all the time), it's perfectly sized so that the front sun shades still go through their motion with out any touching or rubbing, also completely out of view of the rear view mirror, so there is no inconveneince there. See in the guage photos that the owner has a RSM, or SAFC, you could look to install it in the same location as me, so that way your warning lights at the bottom of the rev guage on the cluster are not covered up.
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1204410
Is that three guage holder definitely for 2 1/16" guages???
Also you can get an Autometer A pillar single and Dual pod guage holder. As I am in the states I will source mine here, but have not seen a DIn sized one for three guages.
Modyour car has them here for those who cannot navigate the web...lol
http://www.modyourcar.com.au/?cPath=19_125
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1204493
details
6 Short Street
Dandenong
Vic. 3175
Australia
They are also on ebay for less than that...
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...4526159816&rd=1
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1212308
Actually now I think about it I might have bought the gauge and pod off Ebay. The pod is an autometer one for r33 skylines. I'd have to say I recommend them. Happymeal I reckon I'll get rid of the RSM anyway. Can't get it to cut the speed limit like I thought it would. Feckin thing perhaps I'm just not using it right. Who knows?
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1213337
Well in truth, I have always been able to find the menu setting to cut the speed limiter, but only really had a car with one installed up to a speed where the limiter would have cut it, that was also when I had a different ECU in there (link computer), so I can't testify they always work, but I have not heard any other result of them not doing what they say. In the manual there are two ways of installing the RSM, with speed cut option or without speed cut option (just speed monitor), the speed cut option involves connecting two wires from the RSM loom onto the speed wire out of the ecu and 'snipping' the wire between the connections of the two from the RSM loom. Thereby stopping the signal circumventing the RSM. Maybe your wire is not 'snipped', obviously don;t go snipping a damned thing till you check pin outs lol :cheers: But that situation would stop the limiter feature in the RSM from actively cutting the speed limiliter effect.
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1214004
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
