Well my first time back at wsid in about 8mths with high hopes and that's where it ended. My car is now running better than ever and once again I still couldn't grab a decent time, I feel like headbutting a brick wall :(
I did manage to get a new PB but only by literally a bee's dick.
1. 14.489 @ 94.84mph / 2.190sec
It felt nice and smooth, launch was the usual but for some reason I was -way- down on mph, I didn't even miss a gear :D
2. 15.265 @ 100.23mph / 2.737sec
First run after a 30min rain period. Absolutely no grip on the greazy track and simply bagged em up!
3. 14.145 @ 102.07mph / 2.167sec (<- new PB)
Tried to slam the gears harder, felt smooth once again and managed to get a new PB (old PB was 14.163 @ 100.20mph / 2.148sec).
4. 14.252 @ 100.87mph / 2.166sec
Once again was trying to work the gears hard but was slightly slower even though it felt just as good *shrugs*
5. 14.571 @ 98.02mph / 2.184sec
Used low boost this time (7psi) just for shits n giggles (even though high boost is only about 8-9psi haha).
As you can see my launches are pretty much spot on everytime (even though 2.1xx sec is not overly impressive atleast it's consistent). Sure I could grab some semi-slicks or even drag nitto's etc and probably shave off a tenth or 2 but I shouldn't need to when i'm making a solid 195+ rwkw. I'm a good 0.5sec off the pace of where I believe I should be (and the times others are doing in similar powered cars) and im stumped as to what it is (obviously it's the driver).
Was a great nite of racing (besides the rain periods). Some awesome cars about and probably the biggest meeting i've seen in a good 5-6mths. Wish I left my car in the carpark and spectated instead.
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1203612
i only ended up getting 240RWKW
need to lower compression gonna get a steal head gasget, that will bring her up to the 290 mark.
im gonna buy some slicks soon, just gotta find out how to fit them without removing the brakes, 16" is the only size that can go on.
any1 know where i can get piks from last night??????
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1203992
mods
td06 20G
Greddy Manifold
HKS 50mm External Wastegate
FMIC
Custom Plenum
550cc Injectors
600HP fuel pump
Nismo GMAX twin plate clutch
Power FC
Q45 AFM
KN Air filter
Sard Fuel Pressure reg
Coming
Head gasget
Forgies
Rods
Cams
Big F**K off turbo
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1204002
Sorry mate as I've said several times in the past the 20g wont flow enough to make 290 its impossible, maybe some decent drag radials would be better then slicks as then you don't have to worry about the added cost of front runners
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1204051
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
