Bastard! i was looking at that R32 for ages.
Guess its Snooze you loose!
I ended up getting this one
http://www.prestigemotorsport.com.au/au/st...sp?StockID=2839
Hope we get our cars soon... by soon in mean within 3 months ;)
Anyone know what times we could expect from nearly stock gtr's?
