In theory they COULD Flow more ... people would of heard they flow less.. due to the inlet tract butterfly system they have on teh sandwich plate between the inlet runners and cylinder head. match porting them and removing the butterflies and either putting the plate back in place or using the silvertop plenum and inlet runners.. it been seen already a very dramatic increase in torque and response to more boost
EG. FATGTSR .. did this mod recently and went from making 185rwkw - 15psi and 140rwkw - 8psi on nearer max out fuel system to with GTR injectors to 225rwkw - 14psi ( under 12:1 a/f ratio) and 170rwkw - 6psi
thats a shit load of difference. although the fuel system limited it as well as the inlet design as well.
but before u think about dropping redtop on to silvertop etc etc.... the heads are NOT interchangable from redtop to silver and vise versa.. some stud postioning points are different.. they wont line up.. so if i had a silvertop to begin with i wouldnt even think about a swap, would just a pain in the arse. just so that clears that up.
anyways.
Roy? u want my silvertop long motor? :cheers::D
Thanks Angry but i alreday have enough RB20 parts laying around:(
Well the way i look at it, is Nissan went racing with the R31 GTSR, and when they went racing they effectively built the engine that was later used in the R32 GTST, ie what ppl are referring to as the silvertop engine.
So as you said, there is more then just the inlet system that is different between the two RB20 engines, and the fact that when Nissan went racing they used the 6 port silvertop head...well i would have thought it would be a better starting point for an RB20?!?!?!?!?!?!?!?!?
fair call .. but i dont think anyone really pushed the redtop motor extensively enough to see how the 12port goes
example ..12port holden blue motor ..... flows better when done right compared to a red motor head. but thats exhaust.. so its probably a bad example.. anyways.
If you need the top part of the plenum then let me know, as i think i have a spare plenum at home in Sydney as well as one in Melbourne. The Sydney one is actually 80% polished:)
Also got the std RB20 ECU and one re-written for the TD06 with GTR injectors
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
