Ignition Timing
Guest N/A R33
This may seem like a pretty stupid question to some of you guys but here goes anyway.
How do you connect the timing light to the sparkplug on number 1 cylinder seeing that it's under the coilpack?
The way I think I would do it is take the coilpack out and plug in a normal coil and lead that way giving yourself a connecting point for the timing light.
Steve N:)
https://www.sau.com.au/forums/topic/6467-ignition-timing/
Originally posted by ylwgtr
NO!!!!!Under the module there is a wire loop that you can connect a normal clip on type timing light to.....it looks like a normal speaker type wire
hope this helps!
I have heard that loop is for factory diag i tryed putting a timing light on it and my timing was way out. i think by a few degrees as opposed to timing the actual cylinder..
Maybe someone can varify for sure because it would be good to clear this up, that loop is hell easy to attach timing light to :uh-huh:
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97209
Yep - it is the wire loop at the back of the engine near the silver ignition-module-box-thingy - says so in the Service Manual for my car anyway.
A mate tried the same on his R33 & got the same results.
A very reliable source indicated that you will get maybe a couple of degrees difference in your readings from here when compared to measuring straight from the wire going to the coil itself - but who wants to stuff around taking covers off, etc.
Hope this helps...
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97457
I have done all the work to my car but never ever done the timing on it.
So, you put the plug that was meant to go to cylinder #1 on the black loop wire on the ignition module.
Where does the other wire/s go?
dont get me wrong I am very mechanically minded but no one has ever shown me.
Doc
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97469
Hope this helps...
But a couple of degrees out is not good enough
If this loop is the output from Igniter module straight to firing 1 cylinder then it should be 100% as long as your timing light picks up low level voltages or if it is a CT Current transformer type which picks up the firing pulses as a current...
But when i tried to time it from there all i got was about 8degrees TDC with max clockwise cam sensor turn
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97595
ok....it will show up out because the car is not in service/dianostic mode........run it in service mode and you will get an accurate reading
you could be on to something there?
so use the loop and run in service mode, is there anywhere we can get instructions on how to use service mode?
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-99675
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
