Phews, thanks guys. Mine over heated once and its' cos' of the " sender " sit in the radiator screwed itself once, didn't trigger the thermal fan to work ( this was in a heavy traffic with dirty coolant and on a Melb HOT day, funny enough my old mechanic change my water pump and didn't give me new coolant not to consider a freaking flush ) so yeah. A new unit is on the way from Japan mean while i'm using one off YLWGTR ( Troy the man ).
As for the oil pressure gauge, mine always sit low but for peace of mind i had it tested out with a Mechanical gauge and it read alright.
The factory gauges suck. The water temp will sit on 1/2 until its too late. And dont even get me started about the oil pressure gauge :cheers:
I put a new oil pressure sender from Nissan in the car 20,000kms ago (2003) and its f*cked again already.
mine sits at half too...I know it's working cause it rose a couple of mm's the other day, I didn't want to take any chances so i immediately checked the engine and whadda know.. there was a leak in the radiator hose... I would've saved a heap right there, so what your reading sounds right but if it moves just a little then I'd worry
Mine never moves more than half a needle width, basically you can't see the guage moving.
Really really cold mornings/nights it will sit pretty much dead on half, its hard to tell exactly where it is sitting due to the guage which is decieving.
When the car is sitting in 40degree peak hour traffic where the AMB button reports 50degree's the needle sits 1/2 a needle width higher.
BUT it still doesn't go over ~90degree's, well it never triggers the engine overheat fan which apparently triggers at 90degree's.
The reason why the Skylines raise temp so fast (within 2km's) is the ecu retards ignition timing (can generally felt as a ever so slight flat spot on light throttle cruise and the turbo appears to spool a little quicker) + a few other little bits to get the car up to operating temp ASAP, this reduces emmisions and improves fuel economy.
Once you hit 100degree's the temp guage begins heading to 3/4.
If the needle begins to move around and you notice the engine overheat fan triggers check out the usual clutch fan and radiator blockages.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
